Did you know? 🤔
Need help replacing the Fuel level sensor (Driver side)
2001 - 2007 XC-70
titodj
Year and Model: 04 XC90
Has thanked: 3 times
Been thanked: 0
United States of America
titodj
Post by titodj » Sat Jun 22, 2019 7:32 pm
I was expecting to find it under the metal cover, but is not there...
I'm attaching the picture of what is under the metal cover, and don't see a way to get below that?
2005 2.4 S60
MDK
Year and Model: 1998 xc 70
Has thanked: 0
Been thanked: 28 times
MDK
Re: Need help replacing the Fuel level sensor (Driver side)
Post by MDK » Sat Jun 22, 2019 9:00 pm
So..2005 S60 2.4..the fuel level sensor...the float...is built in to the fuel pump. You have to figure out if you have a plastic gas tank or a steel one. You'll also have to find which chassis number you have... which usually means.. early 2005 or later 2005. The VIN number on the dashboard has all the data you'll need to order any parts...ok? By the way... check the other side
These users thanked the author MDK for the post:
titodj
titodj
Been thanked: 0
titodj
Post by titodj » Sat Jun 22, 2019 11:53 pm
Thank you!
So according to the VIN, the pump that I should use has a level sensor, but also has a long cable that I guess goes connected at the other side of the tank to the sender unit, that also has a level sensor. and I don't know how to reach.
This is the VIN, in case it helps. yv1rs612752447242
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 0
Australia
darylrobert
Post by darylrobert » Sat Jun 22, 2019 11:59 pm
its under the back seat on the other side, youll could need a removal tool if its like the xc70
oragex
Year and Model: S60 2003
Has thanked: 99 times
Been thanked: 290 times
Canada
oragex
Post by oragex » Sun Jun 23, 2019 11:16 am
My level sensor was also very random so I pulled it and cleaned the potentiometer contacts and - perhaps even better - also compressed a little bit the "U" portion of the float metal rod, because when it was sitting on top of the potentiometer it had a little bit of side-play, which may be the reason the gauge was getting stuck. Since that video - sorry about the video quality, not the best - the level gauge is very accurate and I have no problem trusting it. At the end of the video I put a link how to access to the sensor, however that was on my car which has the metal tank - on plastic gas tank cars it's a different access hole and locking ring that requires a special tool sold on Ebay
titodj
Been thanked: 0
titodj
Post by titodj » Sun Jun 23, 2019 12:51 pm
The problem is that I can't reach the sensor on the driver side, there's just a metal plate underneath the round cover.
oragex
Canada
oragex
Post by oragex » Sun Jun 23, 2019 1:24 pm
I don't know about the specific configuration on your car but you can see here after about 5:00 there are two covers under the rear seats - one is hidden under the upper section of the seat and difficult to access (need to remove the upper seat). The picture in your first post seems to be just a hole for other gas tank configurations - that cable is actually an ABS cable
These users thanked the author oragex for the post:
titodj
MDK
Has thanked: 0
MDK
Post by MDK » Sun Jun 23, 2019 2:53 pm
MDK here... that's exactly right Oragex. The hole on the driver's side is a pre-form in case it was to be outfitted with AWD and a saddle tank..
oragex
titodj
Been thanked: 0
titodj
Post by titodj » Mon Jun 24, 2019 10:20 am
Thank you, that's the configuration that I have, behind the back of the passenger side it's the fuel pump, and the sender is supposed to be under the seat on the drivers side, but I can't find a way to reach it.
oragex
Canada
oragex
Post by oragex » Mon Jun 24, 2019 5:02 pm
Is it possible the sender assy is secured to the pump unit itself ? That's how it was on my model year (and a bit tricky to remove, had to separate them inside the tank)
titodj
