07 C70: Adjusting windows after replacing/removing battery Topic is solved
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
I finally locked the roof on a C70 but still had an error message. I disconnected the battery and when I went to reconnect the battery, the windows were out of alignment and then would not adjust upwards after closing the door. After much head scratching, I found that you have to turn the key to position II and press both windows buttons (upwards position) for 15 seconds to reset them. Now they're working...
I'm guessing there's a LOT you do with key position II on these P1s...
Retired:
2015 Volvo S60, T5, 85K
