102993 Bosch or OEM ?
the price difference 10$ vs 55$
is it a critical difference for my 2004 xc70 ?
any other brand price suggestion?
https://www.ipdusa.com/products/4876/11 ... vo-8692071
Bosch or OEM spark plugs?
- Been thanked: 504 times
Bosch 102993 is copper, good for 30K miles.
I use NGK Iridium, good for 60K-80K. About $6/each. Info in forum.
You can also use Bosch Platinum.
Every office has their opinion, here's mine:
If you drive a lot, get the Pt or Ir and swap them out every 3 years.
If you don't, then the Coppers are much cheaper and last 2 years.
Don't let them sit in your head for 5 years because they 'last' 100k
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
I would just get the volvo ones and put a little oil on the threads. but as abscise says pull them out and put them back every three years minimum to keep them from seizing up. The ngk and Bosch are a Chinese copy concern too.abscate wrote: 26 Jun 2019, 15:19 Every office has their opinion, here's mine:
JNavas
- Year and Model: 2008 S60 2.5T
- Has thanked: 1 time
- Been thanked: 4 times
Fine-wire iridium alters the tip projection and combustion characteristics compared to OEM platinum, which is why OEM Bosch Platinum Turbo plugs remain the recommended choice for this specific engine, even if iridium plugs seem to work. Price of a set is about $40 delivered from FCP Euro.Mikele82 wrote: 26 Jun 2019, 12:42 102993 Bosch or OEM ?
The principal advantage of iridium is plug life, typically 100K–120K miles for double-iridium designs compared to 60K–100K for platinum, though many aftermarket fine-wire iridium plugs (like NGK IX) actually carry shorter 40K–50K intervals.
Hope that helps,
John
2008 Volvo S60 2.5T (black with oak interior)
John
- 776 Views
Last post by hu5ker555
- 892 Views
Last post by brickhead
- 610 Views
Last post by volvolugnut
- 3292 Views
Last post by ndphotonl
- 13 Replies
- 3788 Views
Last post by JNavas
