AC in Daughter's 850
Craigd2599
Year and Model: 2007 S40.
Has thanked: 3 times
Post by Craigd2599 »
Hey kids...
My daughter's 850 is giving me fits. The AC stopped working. I jumped around the low pressure switch and it worked so I figured I'd have a week or so to get the stuff together to fix it. On Monday, she was driving to work and heard a "pop" and the freon leaked out. Haven't had time to chase the leak yet but the pop sound seems mysterious. Would a high pressure hose blow like that? I know they have a pressure relief blow-off, could that have been it? Any suggestions on where to look first? As far as I know the entire system was replaced prior to me buying the car in late 2015
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
Ocelot
Year and Model: 1998, S70
Has thanked: 61 times
Been thanked: 17 times
Post by Ocelot »
I know the high pressure hose/pipe in the area of the compressor can break due to rust. I don't know how to say it in proper English, my bad!
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Has thanked: 1609 times
Been thanked: 4064 times
Ocelot wrote: 27 Jun 2019, 05:59 I know the high pressure hose/pipe in the area of the compressor can break due to rust. I don't know how to say it in proper English, my bad!
Engels is uitstekend !!
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
A serious over charge will cause the high pressure side valve to open, and 'bang' once. I did that once when I added two cans with the outside temp only in the mid 60's. Two days later, at 95F in the shade, the valve blew. There was still R134a in the system, enough to drive home with cool air, not ice cold.
Klaus
Craigd2599
So you just recharge?
Craig D
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
So the right way to address this would be to put on a set of gauges and see what's actually going on before randomly throwing parts at it.
Does it still work? If the overpressure valve vented off a little extra charge, then stopped venting, then you may be ok. Gauges will tell you.
If it doesn't still work, maybe something failed catastrophically (i.e. went pop) and now needs to be replaced. If you find something with an improper hole in it, then that probably warrants replacement.
The 850's as they age run into issues with clearance in the AC compressor clutch - things wear, and the clutch doesn't engage properly, hence the "bread clip trick". It doesn't sound like this is your problem from the described symptoms.
There's always the chance that a hose or fitting failed. If you find a hole, fix it. Then evacuate, and if it holds a vacuum, recharge.
When you check it out, let us know what you find!
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
Klausc
Post by Klausc »
Craigd2599 wrote: 27 Jun 2019, 18:34 So you just recharge?
With a pressure gauge. No need to pop again...
Klaus
