Timing Belt Marks Keep Moving
zupta82
Year and Model: 1995 960
Post by zupta82 »
Hello everyone, I have a 1997 850 and I can’ t keep the timing marks to stay put. I first aligned the marks on the crank and then the cam sprockets right on the money and lock the cams with my iPd tool.When I assembled all the new parts (idler,pump,tensioner), I then wrap the belt around everything and go to pull the pin on the tensioner and find that it keeps jumping about a tooth off when I go to rotate the crank. Should I align the crank and cams about a tooth off to compensate for the tensioner as it begins to re-extend after I pull the pins. This is driving me crazy, my bolts on the sprockets have not been touched . I have enclosed some pics
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Active
Past
zupta82
Post by zupta82 »
I’m a little confused do you mean pry up on the roller tensioner arm thing and then pull the pin.
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
When I changed my belt I had to compensate by moving one tooth in the opposite direction so it would all line up after I released the tensioner. It took me about 10 tries to get right. Just keep trying.
RickHaleParker
zupta82 wrote: 27 Jun 2019, 08:06 I’m a little confused do you mean pry up on the roller tensioner arm thing and then pull the pin.
I think you are not getting the belt tight going counter clockwise from crank, intake and exhaust, when you pull the pin that slack is taken up and that is why you are one tooth off.
I loop around the crankshaft, pull tight and loop around intake, then the exhaust, then push the belt over the tensioner, pull the pin. You got to keep the belt tight through the entire process.
Active
Past
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
RickHaleParker wrote: 27 Jun 2019, 13:58
This is a really good tip 👌
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
You don't need cam locking tool at all.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
(1) cam locking tool is probably making things worse, see my suggestion (3) below which can not be done with a cam lock tool
(2) use the standard procedure: always start on the crankshaft then proceed from the right (install belt counterclockwise). Pull the belt tight over intake sprocket, then over exhaust sprocket, etc.
(3) BUT after everything is perfectly aligned and ready to go but before you start putting on the belt, cheat both of your cam sprockets about 1/2 of a tooth to the right (clockwise). This will greatly simplify keeping the belt tight as you traverse through the sequence. Be careful, the exhaust cam wants to jump due to cam lobe pressure, be patient you can get it to sit where you want it.
(4) check the marks when you are done, make sure you rotate a full cycle of the crank by hand and check them again.
You will find suggestion (3) to be super useful!
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
you show being half a tooth off which is not possible. are you turning clockwise to test alignment? (front of engine)
Post by erikv11 »
Likely the angle of the pics is misleading. It's going to be off a whole tooth, and OP does say that in the first post.
