Did you know? 🤔
Cant fill my gas tank
2001 - 2007 XC-70
Earthglyder
Year and Model: 2007 V70
Has thanked: 0
Been thanked: 0
United States of America
Earthglyder
Post by Earthglyder » Fri Jun 28, 2019 7:41 am
'07 V70 140k miles. Pump shuts off while trying to fill the tank. While filling the tank took about 1 gallon then expelled a portion back out onto the ground. Put some absorbent down and tried a 2nd time. Same issue.
oragex
Year and Model: S60 2003
Has thanked: 94 times
Been thanked: 242 times
Canada
oragex
Re: Cant fill my gas tank
Post by oragex » Fri Jun 28, 2019 3:48 pm
From what I remember, this is a blocked vent hose at the tank. This is for an C70 https://forums.swedespeed.com/showthrea ... -Tank-Vent
kranz
Year and Model: '98 V70 NA stick
Has thanked: 0
Been thanked: 4 times
kranz
Post by kranz » Fri Jun 28, 2019 4:24 pm
I have a 2004 V70 with the same problem. I've found that if I let the car sit for 15-20 minutes, then I can drive a short distance to the gas station and fill it. I poked around in the forum and I think there is a topic on this. IIRC, there is some sort of filter box for the evap system that sits near the tank or the rear axle. I think it may be responsible for this problem. I seem to recall, topping off the fuel tank can cause this thing to fail resulting in this problem. I thought I'd find a replacement at the scrap yard, but I'm not keen to be crawling under a car out there.
Les is more.
MDK
Year and Model: 1998 xc 70
Has thanked: 0
Been thanked: 28 times
MDK
Post by MDK » Fri Jun 28, 2019 8:33 pm
The vent is clogged or the charcoal canister is saturated...or both
Georgeandkira
Year and Model: 2007 V70 base
Has thanked: 18 times
Been thanked: 45 times
Georgeandkira
Post by Georgeandkira » Sat Jun 29, 2019 7:17 am
I believe the passive thing to do first is to drive the vehicle to get the fuel level down to 1/4 tank.
Under these conditions the EVAP system's purge cycle can have greater chance of clearing itself.
My brother helped me out whilst filling up before hitting the Interstate. He brimmed my tank while I was in the rest room.
The problem cured itself.
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 56 times
vtl
Post by vtl » Tue Jul 02, 2019 8:35 pm
In my case it was a spider that has built his web/nest at the vent pipe's outlet. You can crawl under the rear bumper and check if the pipe is clear of obstruction.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
MDK
Has thanked: 0
MDK
Post by MDK » Thu Jul 04, 2019 5:48 pm
Hey VTL...MDK here. Can you post a pic so we can see where to look. Obviously on yours the nest is gone. But I would like to see what your looking at.... ppreciate ya
vtl
vtl
Post by vtl » Thu Jul 04, 2019 7:26 pm
I don't have a pic. Nr.45 here:
kranz
Has thanked: 0
kranz
Post by kranz » Fri Jul 05, 2019 12:14 am
I found a description of the problem on an S80 that has a photo looking up from the ground towards the filler neck. I took a peek under my 2004 V70 bumper and found that it has the same arrangement.
http://www.fixya.com/cars/t2562789-2002 ... _shuts_off
Here are other photos of the filler neck with the vent tube
Les is more.
Georgeandkira
Georgeandkira
Post by Georgeandkira » Fri Jul 05, 2019 8:30 am
For everyone's information:
The fitting pointing downward (which the spider homesteaded) has a barb fitting.
It was onto that fitting I shoved a foot of old garden hose so I could blow into it.
I was able to locate the hiss of the escaping air.
It was my bad J-hose.
I demand a medal for that one!
