Hello,
Does anyone know a good alternative to the stock TCV for a 95 850 t5?
I'm currently running a tune that turns up the boost to 1 to 1.2 bar and I've noticed that lately the boost levels have been uneven, and I'm sure that the stock TCV has had enough of it.
I've considered getting IPD's HD TCV but, it's very expensive, and I've read that it's not as good as IPD sets it out to be, so my opinion on that is currently a bit wobbly.
I could always get another stock TCV but, I don't want to buy one that'll just break again.
So, what other options do I have?
Thanks!
Marking "Topic Solved" is functional again. It's the green check next to your post. BTW, please do use this when your question is answered and verified. Thanks!
TCV Upgrade on a 95" 850 T5 wagon
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
Re: TCV Upgrade on a 95" 850 T5 wagon
over at the performance tuning forum there is a diy for the same ipd unit for 25 bucks. Just doesn't have the sticker. but I haven't used it.
dont over look your compressor bypass diaphragm and heavy duty spring. Ipd has that.
- ndphotonl
- Year and Model: 2001 S80 2.4T
- Has thanked: 27 times
- Been thanked: 32 times
I would recommended the Pierburg "HD" unit which is used on Porsches/Rovers. I build the IPD unit, but I wasn't impressed to be honest.
Pierburg TCV 7.22908.03.0
Volvo S80 2.4T Pierburg TCV 7.22908.03.0 by Andy Ramdin, on Flickr
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
Is there really some internal difference?
I can see its half the price of original black Pierburg unit found on these cars ~15€ gray vs ~35€ black (7.22240.13.0)
Nevertheless i ordered one, and will let you know if it works better. Nice to have Porsche 911GT2 piece on your Volvo
Ok its in place now and i actually see some minor improvement in boost pressure @spool, but it cant hold it till redline (1,2-1,3bar), so it has to be the wastegate actuator.
- ndphotonl
A worn old wastegate actuator was the missing link when I optimized my S80 as well. After adding a boost gauge, I found out I was driving on wastegate pressure instead of "normal boost pressure". After replacing it with this Mambatek actuator (I have a 13T turbo), problem solved!
Volvo S80 2.4T New Mambatek Turbo Wastegate Actuator by Andy Ramdin, on Flickr
FlickR images
FlickR images
- 2511 Views
Last post by LUDErunner11
- 343 Views
- 1654 Views
Last post by velorider
- 564 Views
Last post by Ludermilch
- 713 Views
Last post by carboncow
