vibration and hum from a/c fan
Mike Langlois
Year and Model: 2002 V70 & V70 XC
Has thanked: 28 times
Been thanked: 6 times
Post by Mike Langlois »
My 2002 V70 X/C started humming and vibrating when the climate control fan is activated. It gets worse the faster the fans is set. Anyone have any thoughts on that? The car is sitting mostly, during a major stereo upgrade; started, making odd noises that stopped when the fan is stopped, after the car was started today. I'm scrapping a V70 2.4 t and messing with the climate system looks like a challenge.
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
I had something similar a few years back. My problem ended up being dirt and grim had accumulated on the climate control fan blades making it off balanced. I took the unit out to investigate the vibration, and saw the build-up. Once I cleaned the blades and reinstalled, she was quiet as new.
It's not too hard to remove if you don't mind laying on your back in the front passenger foot well. Make sure to disconnect the battery before unplugging the unit. Also check your cabin filter for debris and possibly replace.
Good luck.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Another way is to undo the windshield cowl piece - the large black plastic piece - without removing the wiper arms, just lift if at the passenger side, and look with a flash light at the fan blower, you get a clear view. May try to slide a hand and remove any debris as mentioned above (don't put the garden hose on it). You will loose the black locking pins of the cowl - the center piece needs to be pushed down, may get a few new ones from Volvo
Mike Langlois
Thank you for both suggestions. I think I’ll try pulling the cowl up before I go in underneath.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
The fan motor has a cheap plain (sliding) bearings. Once the grease is gone, the sleeve is gone. Replace the motor/assembly. Need that every 15-20 years.
