Radiator upper neck plastic rim fix (probably any model volvo)
Mikele82
Year and Model: XC70 04 + C30 T5 08
Has thanked: 30 times
Been thanked: 3 times
Post by Mikele82 »
So my upper coolant hose lodged off. turns out the mechanic closed the clamp too close to the edge and it broke edge rib that stops the coolant hose slipping off.
The mechanic said the whole radiator needs replacement because of that. (500$ by a mechanic or 300-150$parts+diy)
but why replace the whole unit if only the little edge rim broke off...
So I just did this old Mercedes trick = 12$.
https://mercedessource.com/store/plasti ... repair-kit
The trick is usually to strengthen it prior to it breaking but with a slight modification its also a fix.
Copper pipe 3$
hi-temp epoxy cement 4$
small stainless screw
A half of a 'hose to hose' connector (5$ 'radiator hose fix kit')
I forgot to take all the pictures of the process, but here is what I have:
First, take coolant fluid out (drain or pump out a bit and use gloves, coolant fluid is toxic) I put a big plastic bag under the top coolant hose for protecting from coolant fluid drops and then disassembled it and dry any coolant residue.
A1- plug the top hole with some foam so no plastic debris falls into the radiator.
A2 - sand inside and out with ruff grit for better hold of epoxy cement
A3 - measure the inner diameter and get a close match copper pipe/tube to fit inner diameter. my xc70 was at about 1.1"
B1 - I couldn't find the exact diameter so got the slightly oversized one.
B2 - Clamp it and cut it open (red line) so you can squeeze it into size.
B3 - Sand the outer surface of copper pipe
C1 - Close it with a hose clamp and check it fits perfect
C2 - Drill one hole on the side through plastic and copper pipe (first plastic, then mark pipe and drill and clean the pipe outside the assembly)
C3 - Check the assembly works with the bolt.
C4 - With clamp on pipe, apply epoxy cement on outer copper and inner plastic.
C5- Insert in a circular motion, align with pre-drill hole and release hose clamp.
C6 - Apply a bit of epoxy on a stainless screw and put it in.
C7 - Clean inside any epoxy residue
PULL OUT "A1" debris foam plug (if you didn't already)
D1 - Cut the 'hose to hose plastic' in half.
D2 - Sand the inside for epoxy grip
D3 - Apply epoxy on plastic and copper hose.
D4 - Insert over the copper edge in a circular motion
D5 - Clean residue epoxy
Wait for cure
I used a 5hr hi-temp epoxy cement so final cure time is about 24hrs.
you can use 5 min epoxy with a shorter final cure, just be sure you are able to fit parts well in time.
Once cured attach coolant hose and clamps (best if new clamp set) and fill coolant.
note to run engine idle and squeeze top coolant hose to get bubbles out and then check and top off the fluid.
It has been a year now and had no heat issues or leaks.
180,000mil XC70 2004
Tammymears
Year and Model: 2005 xc70
Post by Tammymears »
Does anyone know of someone who could do this? It seems very costly to get an entire radiator for this one piece. I’m just unable to do it on my own, and I definitely can’t afford a new radiator at this time.
Has thanked: 1609 times
Been thanked: 4063 times
Where are you located ?? Might be someone nearby to help with that repair.
Ethan5150
Year and Model: 1994 850 Turbo
Has thanked: 1 time
Been thanked: 2 times
Post by Ethan5150 »
Outstanding fix and post Mikele82 - I did this last weekend and it worked great - EXACTLY as you described! Thank you so much for taking the time to post this. If I wasn't broke I'd send you a gift basket. My sincere gratitude and blessings will have to suffice for now. Consider your karma hereby boosted! Mahalo nui 🙏
Great fix from sometime ago!
Wait for cure
I’m going to recommend 24 hour JB Weld for this. It’s much harder to get the mix right on five minute epoxy without a dispenser, the 24 hour cure version is more forgiving. Let it sit for a day before recharging.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
abscate wrote: 14 Feb 2024, 03:50
Wait for cure
slow cure epoxy sticks far better than 5 minute junk, you can peel 5 min epoxy off after a while.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
If you are short of budget, Spectra is a decent brand.
My 2007 S60 with 118K miles had the rad replaced in
2016 by the PO using Spectra.
I posted the PN somewhere in this forum.
