IPD sale XeMODeX - Experts in Volvo Electronics Free shipping all USA - Experts in Brakes
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
Wouldn't pass State Inspection
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
MDK
Year and Model: 1998 xc 70
Has thanked: 0
Been thanked: 28 times
United States of America
MDK
Re: Wouldn't pass State Inspection
Post by MDK » Tue Jul 09, 2019 9:44 am
State of Ohio flag... I'm in Cincinnati Mr Detail...I don't know what part of Pennsylvania you're in. I just hate seeing someone jerked around because the think they"gotcha". if you had all your parts together and came to Cincinnati ... I'd fix it. The dealership here cringes when I come in... I'M TAKING IT ALL APART!! RAHHHH!!!! hahaha
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 13 times
Been thanked: 2 times
Mr. Detail
Post by Mr. Detail » Tue Jul 09, 2019 10:03 am
MDK, I live in suburban Philadelphia. far enough outside the city that I have wild foxes running thru my back yard. :)
I may just come and see you.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 20 times
Been thanked: 18 times
XC70Rider
Post by XC70Rider » Tue Jul 09, 2019 2:40 pm
E Showell wrote:
Mon Jul 08, 2019 5:54 am
Changing rear brake pads is exceedingly simple. Drive out two pins with a drift, remove pin retaining clip in the process, wiggle out old pads. Compress piston with a big pair of channel locks or large c clamp. Wiggle in new pads and drive in new pins with clip.
Of course, car is on jackstands with rear wheel removed.
Remount rear wheel and bed in new pads. Voila.
+1
Changing pads is easy. Of course you need the proper tools, brake grease, and brake cleaner. I installed Autozone's Duralast Maxi Ceramic pads 13k miles ago and they're still thick & smooth. Nice gripping power with very little brake dust. Another good factor is with the Limited Lifetime warranty I can swap them at Autozone with no questions asked.
Front: DGC794
Rear: DGC795
E Showell
Year and Model: V70R '06 AWD Auto
Has thanked: 9 times
Been thanked: 55 times
E Showell
Post by E Showell » Tue Jul 09, 2019 3:44 pm
I might want to hunt up a video on the rear brake pad change if I hadn't done it before. Wiggling the old pads out and the new in is second nature if you've done it before, but if you haven't done it, or seen it done, it might be nice to see someone do it before you attempt it. Nonetheless, it is dead simple, but don't forget to compress the caliper piston to make wiggling the pads in and out much easier, since the new pads are going to be thicker than the old ones they are replacing and you will need the extra clearance.
'99 V70 NA FWD Auto, dark blue (actively for sale)
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
Mr. Detail
Mr. Detail
Post by Mr. Detail » Wed Jul 10, 2019 6:04 am
Thank you XC70 Rider and E Showell for your tips. I think I will attempt it.
E Showell
E Showell
Post by E Showell » Thu Jul 11, 2019 3:29 am
Just edited my post above with a little extra info.
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 274 times
Been thanked: 853 times
Trinidad & Tobago
Post by abscate » Thu Jul 11, 2019 3:39 am
You can make the piston compression easier by easing the brake bleeder screw a turn and catching the small amount onto a paper towel. A screwdriver can pry the piston back with the pads still in with a bit of lever force.
If the bleeder snaps, don’t fret, just crack the line at the caliper slightly, push the fluid out, retighten.
When all done ,flush with water , dry off, look for leaks.
Also, don't be afraid to scrape the top and bottom of the caliper where the pads slide in, HARD with a stiff screwdriver. In the NE, the metal will corrode and swell, and the new pads might appear to be too wide up-and-down. Ive even had to chip away some rust to make new ones fit, in chunks.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
