Maintenance reminder comes on every 2 to 3 days
5ft24
Year and Model: 2005 XC90 V8 AWD
Has thanked: 20 times
Been thanked: 12 times
Post by 5ft24 »
As the title says, the time for maintenance reminder comes on I reset it I hear the beep from the dash the yellow triangle flashes it disappears for 2 to 3 days and then comes back on is there a way to keep this thing off. No trouble codes set VIDA and dice give it a clean bill of health
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
First time I see such issue, it should stay clear once you hear the beep and the T1 gets the miles back. Maybe try disconnecting the battery overnight ? (have the key in POS II when reconnecting it)
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
I recall having the same issue on my 2004 XC90 T6. If I recall correctly I found another "reset" procedure and that worked.
What is the procedure you are using?
5ft24
Post by 5ft24 »
Key to position I, push odometer reset and hold it, key to position II, after yellow triangle.flashes twice, release button, dash beeps, key off, then start it. Message gone... For a couple days
SuperHerman
My daughter has my XC90 and if I recall I have the "successful" sequence in the glove box. When the car is returned I will update.
Other item - the reminder light, if I recall correctly, starts to appear before the actual mileage of the computer scheduled maintenance. As one gets closer to the mileage the frequency interval starts to shorten and the display pops up more often. If I recall correctly, the message disappears after a set amount of seconds. So the disappear you may be seeing could be the program in operation rather than the reset working. (But if it stays off it works of course).
oragex
Post by oragex »
There might be two official Volvo procedures depending on the year (however there are many variants over the internet as people also make some variations when trying these)
This is what worked for me, notice I don't keep the key in POS I at the beginning (I don't think it's needed) and also I don't care about how many flashes, just a couple then let go - perhaps even 1 is enough. Notice I'm on T1 trip meter and when I turn the key to POS II the T1 goes to 0 and the triangle flashes, then when I release the button the T1 goes back to its miles, the triangle vanishes and also the Service message vanishes as well (the display it's hidden by my hand) www.youtube.com/watch?v=CTAI6V7Elp4
5ft24
Post by 5ft24 »
so I read parameters from the DIM. Service interval was "Invalid Value", as was engine run time for service and Mileage interval for service.
set those back to default values, so now we see if the message stays gone
