Did you know? 🤔
1997 850 GLT Engine Swap (M4.3 M4.4 AC compatability issue)
bmdubya1198
Year and Model: '98 V70 GLT
Has thanked: 28 times
Been thanked: 101 times
United States of America
bmdubya1198
Re: 1997 850 GLT Engine Swap
Post by bmdubya1198 » Sat Jul 06, 2019 4:56 pm
You should be able to have your current ECU tuned for this setup. It's not the ECU you're changing, it's the engine. Honestly I wouldn't bother finding another 2.4 if you want the HPT, the engine itself shouldn't cause an issue with the right tune. You have more room for power with the 2.3 with its lower compression.
Now, if there are known issues tuning this particular part number ECU (forgive me, I'm not too familiar with each particular version), that could likely be worked around by using a 1997 T5 ECU, no?
Anyway, if you're having ECU-related AC issues, that likely won't be changed with a tune. That's a question better suited for Lucky at ARD. It may be worth starting a thread over on Volvospeed, there are a few M4.4 gurus over there that could probably answer your questions.
Read over this thread too, I'm sure it includes AC info... http://volvospeed.com/vs_forum/topic/15 ... g-for-m44/
Also see these links... https://m44.fandom.com/wiki/M44_Wiki
http://volvospeed.com/vs_forum/topic/14 ... -overview/
2000 V70R Venetian Red/Charcoal M56 Swapped 191k
2000 S70 GLT Mystic Silver/Taupe 2??k
2003 S60 2.4T Silver/Black 108k
2007 XC90 V8 AWD Sport Titanium Grey/Black 160k
1993 944 Base Beige/Beige 221k
1992 Miata Mariner Blue/Black 146k
1998 V70 GLT Black/Beige 193k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k- Never should have sold it
Need used parts? PM me!
Chuck W
Year and Model: 97 854 T5
Has thanked: 11 times
Been thanked: 22 times
Chuck W
Post by Chuck W » Sat Jul 06, 2019 5:11 pm
Did you not read my post? ;)
I recently went through ALL of this on a '97GLT. The AC issues on an 97 GLT are for sure part of the tune ECU. I went through ALL of that thread, and the Wiki.Tried several ECUs, as we were planning upgrades on the car and wanted the tuning capabilities.
If he doesn't care about AC, then it doesn't really matter. If he's going to want it eventually, then it will.
bmdubya1198
bmdubya1198
Post by bmdubya1198 » Sat Jul 06, 2019 7:58 pm
I did not, and I guess it shows! I think I missed your first post due to the newest post being your following post at the time I came back to this thread. NOW I've read through it, great info!
I had always been told '97-'98 turbo models are virtually identical. Good to know that's not the case for the ECU!
Has thanked: 221 times
Been thanked: 729 times
Trinidad & Tobago
Re: 1997 850 GLT Engine Swap (M4.3 M4.4 AC compat issue)
Post by abscate » Sun Jul 07, 2019 2:38 am
BrickyardCustoms wrote:
Wed Jul 03, 2019 6:49 pm
Hello all,
Used the forums for advice from time to time but this is my first post. My 1997 850 GLT has a ruined block due to getting too hot after a heater core blew. As many of you know these came with a 2.4 LPT, and although they’re cheap and easy to find, I would like to put in a 2.3 (B5234T) or whatever variation. I was curious as to how much of a plug and play the swap will be. I assume it’ll bolt to the auto tranny just fine, and I’m under the impression that with simply a different tune (will be from ARD again) the car should be fully functional. Is this correct or has anyone done this? I’m going for more power and had always wanted a 2.3 swapped in down the line, but now seems as good a time as ever. Any advice and input is appreciated. Thanks!
(Added discussion about Motronic AC issue to title for search)
Chuck W
Chuck W
Post by Chuck W » Sun Jul 07, 2019 7:29 am
This is the same info I was going off of when I got into the engine swap on this thing. All signs pointed to it being just a plug-n-play with the ECU. When I ran into the roadblock and dug deeper, it was pretty much a dead end.
BrickyardCustoms
Year and Model: 1997 Volvo 850
Has thanked: 4 times
Been thanked: 0
BrickyardCustoms
Re: 1997 850 GLT Engine Swap (M4.3 M4.4 AC compatability issue)
Post by BrickyardCustoms » Sun Jul 07, 2019 8:42 am
The car has an ARD OEM R tune, but it wasn’t on my original ECU, they just sent me an entirely different one.
BrickyardCustoms
Been thanked: 0
BrickyardCustoms
Post by BrickyardCustoms » Sun Jul 07, 2019 7:58 pm
Well I’ve decided to go the no AC route and go with the 2.3. Gonna be doing a few mods with the swap as well as a few other small things, and I may start a little build thread so stay posted. Also does anyone have any 96-97 2.3t motor that they would sell that’s in decent shape? I found one out of Minnesota but have been SOL in regulated to anything local or eBay. If so please PM me! Build and further questions will be in a new thread, so be on the lookout for that. Thanks
bmdubya1198
bmdubya1198
Post by bmdubya1198 » Sun Jul 07, 2019 8:31 pm
Search on car-part.com. There may be one listed nearby. Also check lkqonline.com. Most places will also ship it to you if you can't find one locally.
Of course if you can find one someone's selling privately, that would be ideal!
These users thanked the author bmdubya1198 for the post:
BrickyardCustoms
Chuck W
Chuck W
Post by Chuck W » Mon Jul 08, 2019 7:05 am
One of the benefits of the RN swap is getting rid of the early oil cooler/lines. I was VERY happy about that when we swapped motors on the wife's car. No more leaky oil lines/connections. Even if you stay with an N engine, I would suggest the RN oil pan/cooler swap. I'll be doing that on my '97 T5 when I get under it for the manual swap.
bmdubya1198
bmdubya1198
Post by bmdubya1198 » Mon Jul 08, 2019 8:10 am
For sure... definitely get rid of those leaky lines if you can! That said, the oil cooler on my 2000 is leaking between the cooler and the pan :lol: .
