IPD sale Volvo Parts
Did you know? 🤔
Still Crank No Start. Very Strange
2001 - 2007 XC-70
goldmandan
Year and Model: 1999 S 70, 2000 V70
Has thanked: 0
Been thanked: 0
Sweden
goldmandan
Re: Still Crank No Start. Very Strange
Post by goldmandan » Tue Jul 09, 2019 7:31 am
would a bad maf or dirty maf cause it not to start, only sometimes?
Dan
Has thanked: 188 times
Been thanked: 600 times
Trinidad & Tobago
Post by abscate » Tue Jul 09, 2019 8:48 am
Dan
Possible but I would say rarely. You can disconnect it, then try (the car will run on a rmp/fuel map in software if there is no MAF signal)
You will have to clear MAF code after that.
Dont unplug/plug MAF with ignition on, shut everything off.
goldmandan
Has thanked: 0
Been thanked: 0
Sweden
goldmandan
Post by goldmandan » Tue Jul 09, 2019 11:19 am
i read ecm2400 is a short to ground in the wire from ecm to cem. Would make sense as the fuel pump relay was replaced already and i just put a new one in. no change. And the CEM does have a yellow wire going to starting/charging system. I think i may have found the culprit as the ecm2400 triggers right after i erase it and crank again.
