Yesterday we drove XC90 2012 to a rooftop garage, to watch July 4th fireworks. We opened the moonroof all the way so the two girls could stand up and stick their heads out to enjoy the show.
ooo and aaa later, I found out that the moonroof wasn't able to close after it closed about 1/4 of the way (you know, upon the first press, it would open to about 3/4 and a second press, it would open all the way).
I wonder if anyone on the forum has had this problem. I could use some tips. Cheers.
After watching the fireworks through the open moonroof .....
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
You may also post on the S60 forum because it's the same sunroof. As for the issue I don't have a clue, maybe try locking unlocking 3 times the driver's door (or all doors) with the key fob
May also try a battery reset - disconnect the negative at the battery over night. Be sure to have the key in POS II both when disconnecting and reconnecting, also test the trunk lock works with the key mechanically before shutting the trunk closed.
Now if the kids bumped somehow on the side of the glass and broke/misaligned something, then it's going to be a different approach
hot9000
- Year and Model: 2012 XC90
- Has thanked: 2 times
I tried the lock/unlock 3 times thing and it didn't help unfortunately. I am going to talk to a shop Monday and see what happens. I will report back if there is anything worth sharing.
I also searched "moonroof" in S60 forum but didn't find much.
Thank you very much for replying to my question though.
- 595 Views
Last post by VolvoXC90T6party
- 702 Views
Last post by draser
- 1018 Views
- 2965 Views
Last post by JNavas
- 1642 Views
Last post by Swedeneed
