I am trying to swap out the headlight ballast in my wife's 2012 XC70 T6 and cannot seem to remove the 12V plug from the socket on the ballast. I tried applying pressure to the plug release tab with a small screwdriver seriously disfiguring the tab in the process (see link to image). I stopped short of completely mangling the connector. I cannot seem to remove the plug from the socket on the ballast. What am I missing here? Anyone have any suggestions? Thanks!!
https://drive.google.com/file/d/1XkMPW_ ... sp=sharing
Stuck 12V Bi-Xenon Ballast Connector
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Have you solved this issue? Are you intending to replace a bad unit? If so use carburetor cleaner or electrical contact cleaner and spray the area down. If it does not work then submerge the area and let it soak for a bit. Test it on the wiring to see if it becomes sticky just in case.
Worse case slit the sides of the socket and use two thin flat heads to pry it out from the opposite sides.
https://www.volvopartswebstore.com/prod ... 44459.html
- 30 Replies
- 7600 Views
Last post by Bridge2Fairway
- 2953 Views
Last post by 93SCMax
- 652 Views
Last post by shmizoke
- 740 Views
Last post by Ozark Lee
- 2497 Views
Last post by Icewater66
