Did you know? 🤔
Stuck 12V Bi-Xenon Ballast Connector
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
RichS
Year and Model: 2012 XC70 T6
Has thanked: 0
Been thanked: 0
United States of America
RichS
Post by RichS » Sun Jul 07, 2019 1:13 pm
I am trying to swap out the headlight ballast in my wife's 2012 XC70 T6 and cannot seem to remove the 12V plug from the socket on the ballast. I tried applying pressure to the plug release tab with a small screwdriver seriously disfiguring the tab in the process (see link to image). I stopped short of completely mangling the connector. I cannot seem to remove the plug from the socket on the ballast. What am I missing here? Anyone have any suggestions? Thanks!!
https://drive.google.com/file/d/1XkMPW_ ... sp=sharing
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 23 times
Been thanked: 39 times
MoVolvos
Re: Stuck 12V Bi-Xenon Ballast Connector
Post by MoVolvos » Wed Jul 10, 2019 9:28 pm
Have you solved this issue? Are you intending to replace a bad unit? If so use carburetor cleaner or electrical contact cleaner and spray the area down. If it does not work then submerge the area and let it soak for a bit. Test it on the wiring to see if it becomes sticky just in case.
Worse case slit the sides of the socket and use two thin flat heads to pry it out from the opposite sides.
https://www.volvopartswebstore.com/prod ... 44459.html
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
