Did you know? 🤔
PCV R&R - Losing the battle to the dreaded hidden Intake bolt Topic is solved
2001 - 2007 XC-70
a3inverter
Year and Model: 2006 V70
Has thanked: 6 times
Been thanked: 5 times
United States of America
a3inverter
Re: PCV R&R - Losing the battle to the dreaded hidden Intake bolt
Post by a3inverter » Wed Jul 10, 2019 5:48 am
One other note on the wobble extensions (at least the Pittsburgh/HF one that I have)...the orientation of the ball bearing that retains the socket matters. When the socket wobbles to the side that has the ball bearing, the angle is more limited than the other 3 sides. Not by much, but every little bit helps.
Something like the attached pic might be ideal...might trying playing some more with a crowsfoot and my bench grinder if the wobble approach doesn't work. Or have a friend weld up a piece of bar stock with the head of a bolt welded to the side facing the front of the car (this would get taped to a socket + extension) and a 10mm socket welded to the side facing the manifold bolt.
a3inverter
a3inverter
Post by a3inverter » Wed Jul 10, 2019 6:02 am
Or a flare crows foot. Most of the non-flare wrench style have faces that are parallel to the flats of the square hole for the extension. Some crows foot ones are offset slightly...maybe just enough!
oragex
Year and Model: S60 2003
Has thanked: 94 times
Been thanked: 242 times
Canada
oragex
Post by oragex » Wed Jul 10, 2019 7:55 am
While there, remember that these non turbo intakes manifolds may have a large attaching bracket underneath (need a mirror to see it), so if after releasing the bolts the intake feels like it doesn't want to come out, look underneath for this bracket
These users thanked the author oragex for the post:
GlennG2759
Has thanked: 287 times
Been thanked: 904 times
Trinidad & Tobago
Post by abscate » Wed Jul 10, 2019 8:11 am
That SK CrowFoot is a thing of beauty designed by someone who understands clearances.
If you flip it over, you get about a 30 degree swing on the flat position
That 12 pointer would work, too, nicely
Link To Volvo Glossary
a3inverter
a3inverter
Post by a3inverter » Wed Jul 10, 2019 8:21 pm
Here's a great view of the challenge. Bolt is hidden behind the bump out on the lower right of the thermostat housing. You are limited to the right by the top sensor bolt, you can't come from under the bump out and the bottom of the intake manifold blocks you as well. Crows foot flare wrench has been ordered.
These users thanked the author a3inverter for the post:
GlennG2759
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 69 times
Been thanked: 8 times
GlennG2759
Post by GlennG2759 » Wed Jul 10, 2019 8:31 pm
Good thing it only has to be loosened
a few turns. Please post how you make out. Did you go with SK tool?
a3inverter
a3inverter
Post by a3inverter » Thu Jul 11, 2019 4:31 am
Glenn - I purchased a Snap-on version of the same instead because it appeared to have better overall dimensions for fitting into the space. It won’t show up until Monday but I’ll report back once I try it.
GlennG2759
Has thanked: 0
Been thanked: 126 times
Post by cn90 » Thu Jul 11, 2019 5:51 am
Interesting photo...
So, for this area (thermostat area), the setup for 2006 V70 NA 2.4 is different from 2.5T?
GlennG2759
GlennG2759
Post by GlennG2759 » Thu Jul 11, 2019 6:26 am
I'm new to P2's so I really don't know. I played around with with various 1/4 extensions and was able to get on the bolt head, but not confidentially enough to give it a crank. I was thinking that if that tang on the thermostat housing isn't a gasket mating surface and just from the casting, a little creative work with a die grinder might give more clearance. Step 2 instruction from factory when building one these engines must have been "put 10 mm IM bolt in lower right on head"
oragex
Canada
oragex
Post by oragex » Thu Jul 11, 2019 7:07 am
have you seen this ?
GlennG2759
