Did you know? 🤔
PCV R&R - Losing the battle to the dreaded hidden Intake bolt Topic is solved
2001 - 2007 XC-70
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 55 times
Been thanked: 6 times
United States of America
GlennG2759
Re: PCV R&R - Losing the battle to the dreaded hidden Intake bolt
Post by GlennG2759 » Thu Jul 11, 2019 7:18 am
Thank you, I looked at FCP video which for some reason they make everything look easy. I missed this one. Looks like the key is 3" wobble extension at the socket. I tried different variations, but not this configuration. I will try tonite !!!
Has thanked: 221 times
Been thanked: 729 times
Trinidad & Tobago
Post by abscate » Thu Jul 11, 2019 7:27 am
Just had a look at my 2.4 NA
This is a classic case of fighting access with a special tool rather than getting good access with some extra work
Three M8 bolts and serp belt allow the PS pump to be pulled forward.
Cover alternator with plastic bag, remove thermostat front half with two Torx
Now the nub is gone and you have a straight shot at the M6 IM bolt
If you are even smarter, wrap the IM work into your coolant change interval and dump/change coolant and hoses on the same ticket, and the 'extra work' is saved later.
You can take the serp belt off with a broom handle to tension the pulley. Its much harder to put it on with a broom handle. Worst case, drive car to AZ without serp and borrow theirs.
Removing and replacing the thermostat cover is documented here - you have to be bit careful without the tool but its not brain science nor rocket surgery
oragex
Year and Model: S60 2003
Has thanked: 88 times
Been thanked: 205 times
Canada
oragex
Post by oragex » Thu Jul 11, 2019 8:24 am
In fact, it has to be a 2" extension at the socket - I tried at 3" extension and it didn't work. My extensions are indeed the wobble type, but I set it to be fixed (it has two setting when you put the socket on it). I warmly suggest also to secure the socket tight on the extension using a piece of paper because I dropped and lost my socket
This bolt near the thermostat for the 2003-2009 thermostats on non turbo engines it's the toughest guy to reach, the same bolt on the turbo engines with either the older or the newer thermostat model is easier to reach
a3inverter
Has thanked: 6 times
Been thanked: 5 times
a3inverter
Post by a3inverter » Thu Jul 11, 2019 9:07 am
I believe that nub is mirrored on the other half of the casting so you still need to get around it.
The other potential issue is that the gasket between the halves isn’t available from Volvo separately- at least according to the parts guy and his picture from Vida at my local dealer.
I will try to verify later today.
Trinidad & Tobago
Post by abscate » Thu Jul 11, 2019 9:27 am
:evil: :evil: :evil: :evil:
a3inverter
a3inverter
Post by a3inverter » Thu Jul 11, 2019 11:52 am
Yeah, imagine my joy. The images from VIDA (and from all the ones I found online) are from the serpentine belt side so you can't see the nub...but I got a finger back there and felt it.
Has thanked: 0
Been thanked: 100 times
Post by cn90 » Thu Jul 11, 2019 11:58 pm
The Volvo engineers should be proud that due their design, this particular 10-mm bolt generated 5 pages of discussion LOL!
Well, in their defense, the I.M. is almost the same as Volvo 850, S70, but they modified the thermostat housing, partially blocking this infamous bolt!
chrism
Year and Model: S80 / 2005
Has thanked: 0
Been thanked: 19 times
chrism
Post by chrism » Fri Jul 12, 2019 6:18 am
Consider replacing that bolt with a torx head bolt. It might make it easier on the next person that has to loosen it.
Has thanked: 0
Post by cn90 » Fri Jul 12, 2019 7:00 am
From the car mfg standpoint, the pressure of cranking new model is intense.
Very often they take parts from previous generations (everyone from Volvo, Mercedes, BMW, Honda etc. does it) and install in the next gen.
In the Volvo case, the I.M. is virtually unchanged from previous gen, but they changed the thermostat housing, partially blocking this bolt. They then issue new procedure/tool to address the issue. This happens in almost all car mfgs.
chrism
Has thanked: 0
chrism
Post by chrism » Fri Jul 12, 2019 7:12 am
Another crazy idea I’ve considered for that pesky bolt.....
The manifold flange is about 1/2” thick where the bolts go through it. What if you ground off 1/8” or 3/16” of material in the area of that bolt and then used a bolt that’s that much shorter. It would provide 1/8” or 3/16” additional clearance between the bolt head and the thermo housing.
