car won't start and run
Vixvolvo
- Year and Model: 1998 V70R
- Has thanked: 3 times
I've changed the spark plugs wires and distributor rotor. my car still won't start and run. im thinking the ignition wire is bad or I've also been told that it could be the timing belt brakeing or the crank position senser.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
A little more info would be useful.
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
Are the cams turning when trying to start the car?
Have you jiggled around the AMM connector?
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
Vixvolvo
the check engine light is on but it's because the previous owner changed his own oil and didn't have the tool needed to reset the check engine light after changing the oil. I haven't checked for codes nor the fuel system but I did check for spark and i got none which is why i changed the spark plugs wires and rotor for the distributor.
brunocerous
- Has thanked: 303 times
- Been thanked: 43 times
Was it running before you changed the spark plug wires and distributor rotor?
If so, I might re-check the order of the wires and ensure good connections at the distributor.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
Can you hear the fuel pump run when you turn the key on? Check for fuel pressure at the rail. there is a valve at the driver's side end. unscrew the cap and press the valve for a second. If it doesn't squirt out under pressure, take the 4 torx screws out at the fusebox cover on the cowl and remove the fuel relay. Try jumping it with a big paper clip. Search here for which 2 terminals to jump as there are 4 or 5 depending on model. There is another relay that is grey right on top the radiator with a 4 wire plug that will cause this. Rap it a few times with the back end of a screwdriver and see if that helps.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- 16 Replies
- 3341 Views
Last post by MadeInJapan
- 28 Replies
- 11732 Views
- 17 Replies
- 6407 Views
- 588 Views
Last post by doublebug
- 1477 Views
Last post by Ou2mame
