Did you know? 🤔
car won't start and run
Vixvolvo
Year and Model: 1998 V70R
Has thanked: 3 times
Been thanked: 0
United States of America
Vixvolvo
Post by Vixvolvo » Tue Jul 09, 2019 11:00 am
I've changed the spark plugs wires and distributor rotor. my car still won't start and run. im thinking the ignition wire is bad or I've also been told that it could be the timing belt brakeing or the crank position senser.
Vixvolvo
Been thanked: 0
Vixvolvo
Re: car won't start and run
Post by Vixvolvo » Tue Jul 09, 2019 11:01 am
any help would be appreciated.
Chuck W
Year and Model: 97 854 T5
Has thanked: 11 times
Been thanked: 22 times
Chuck W
Post by Chuck W » Tue Jul 09, 2019 11:15 am
A little more info would be useful.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 21 times
Been thanked: 38 times
BEJinFbk
Post by BEJinFbk » Tue Jul 09, 2019 1:33 pm
Is your Check Engine light on?
Have you scanned for codes?
Checked fuel and spark?
These users thanked the author BEJinFbk for the post:
Vixvolvo
alschnertz
Year and Model: 1995 854T
Has thanked: 1 time
Been thanked: 7 times
alschnertz
Post by alschnertz » Tue Jul 09, 2019 1:43 pm
Are the cams turning when trying to start the car?
Have you jiggled around the AMM connector?
These users thanked the author alschnertz for the post:
Vixvolvo
'84 Prelude
'06 MPV
'13 Ford Focus SE
Vixvolvo
Been thanked: 0
Vixvolvo
Post by Vixvolvo » Tue Jul 09, 2019 6:09 pm
the check engine light is on but it's because the previous owner changed his own oil and didn't have the tool needed to reset the check engine light after changing the oil. I haven't checked for codes nor the fuel system but I did check for spark and i got none which is why i changed the spark plugs wires and rotor for the distributor.
Vixvolvo
Been thanked: 0
Vixvolvo
Post by Vixvolvo » Tue Jul 09, 2019 6:11 pm
I don't know how to check if the cams are turning when trying to start the car nor what and where the ANN connector is.
brunocerous
Has thanked: 34 times
brunocerous
Post by brunocerous » Tue Jul 09, 2019 6:14 pm
Was it running before you changed the spark plug wires and distributor rotor?
If so, I might re-check the order of the wires and ensure good connections at the distributor.
2004 XC90 AWD
1998 V70 T5, AT, project
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Vixvolvo
Been thanked: 0
Vixvolvo
Post by Vixvolvo » Wed Jul 10, 2019 12:33 pm
no. it wouldn't start
greg850r
Year and Model: a long list
Has thanked: 4 times
Been thanked: 9 times
greg850r
Post by greg850r » Wed Jul 10, 2019 1:15 pm
Can you hear the fuel pump run when you turn the key on? Check for fuel pressure at the rail. there is a valve at the driver's side end. unscrew the cap and press the valve for a second. If it doesn't squirt out under pressure, take the 4 torx screws out at the fusebox cover on the cowl and remove the fuel relay. Try jumping it with a big paper clip. Search here for which 2 terminals to jump as there are 4 or 5 depending on model. There is another relay that is grey right on top the radiator with a 4 wire plug that will cause this. Rap it a few times with the back end of a screwdriver and see if that helps.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
Parts cars not included
