IPD sale Volvo Parts
Did you know? 🤔
05 S80 replacing HID bulbs - REMOVE THE BUMPER??!
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
850TurboTurtle
Year and Model: 96 850T, 05 S80T6
Has thanked: 4 times
United States of America
850TurboTurtle
Post by 850TurboTurtle » Tue Jul 09, 2019 10:13 pm
Is it true I have to remove the front bumper in order to change the HID bulbs in my 05 S80? I'll admit, I can't see an easy way into them from the back.
And, does anyone know exactly which bulbs it takes? There are large rectangular cooling fins on the back of the headlamp area, not a circular cover that screws off. These are the bulbs that dim by rotating the bulb position inside the housing, not with a different element.
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 6 times
Been thanked: 15 times
MoVolvos
Re: 05 S80 replacing HID bulbs - REMOVE THE BUMPER??!
Post by MoVolvos » Wed Jul 10, 2019 3:06 am
Not sure if you need to remove the bumper but here is the diagram for the assembly. Bulb is #17
Assembly
https://www.volvopartswebstore.com/show ... ct=1193522
Bulb - D2R Xenon
https://www.volvopartswebstore.com/prod ... 89833.html
Bumper Removal - Earlier Model
https://www.youtube.com/watch?v=tLdACpQGev8
These users thanked the author MoVolvos for the post:
850TurboTurtle
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
MoVolvos
MoVolvos
Post by MoVolvos » Wed Jul 10, 2019 3:19 am
Bumper removal seems unnecessary?
https://www.justanswer.com/volvo/9lf0v- ... -bulb.html
Better Information - Link Below
https://www.justanswer.com/volvo/4de6s- ... light.html
ALLDATA with Diagram Shows Removal w/o Bumper Removal
http://ww2.justanswer.com/uploads/PENTI ... _volvo.pdf
850TurboTurtle
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
850TurboTurtle
850TurboTurtle
Post by 850TurboTurtle » Wed Jul 10, 2019 1:29 pm
You guys are awesome. :-)
MoVolvos
MoVolvos
Post by MoVolvos » Wed Jul 10, 2019 5:51 pm
I wish I could have it that easy also. Due to moisture in the interior of both light assembly I do have to remove the bumper and disassemble it to clean before reapplying fresh sealant. While I'm in there I also need to replace the battery in the siren module.
Do cross reference with other websites on the bulb as some say Xenon while others Bi-Xenon? Let us know how it turns out?
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
850TurboTurtle
850TurboTurtle
Post by 850TurboTurtle » Wed Jul 10, 2019 6:46 pm
It appears that Xenon means xenon hi beam and halogen low beam. What I have is Bi-Xenon, where the bulb shifts position to change the aim on the beam, but there is only one bulb on all the time. It seems the key is just to know what type of bulb you are replacing. Mine was a D2R bulb which does the high and low.
MoVolvos
MoVolvos
Post by MoVolvos » Wed Jul 10, 2019 9:02 pm
Doing some research I found my 08 C30 T5 has Xenons as low beam while the H7 is for high beam in operation. Volvo has two diagrams with basically the same headlight assemblies (minus 5 parts on one). The bulbs have differing descriptions but the same parts number for both.
(D2S 35W vs D2S 35W Xenon).
As for the Bi-Xenon it is as you described 1 bulb for both high and low beam using mechanical means to move the reflector or bulb. Thanks.
https://www.volvopartswebstore.com/prod ... 83581.html
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
