Engine running for xc70 but its not moving when put in drive gear or reverse gear
Mikebanda
Year and Model: 2004 xc70
Post by Mikebanda »
:D
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Is there a turbine-like whining noise when you rev over 1,500rpm?
Symptoms point to either a transmission pump failure or filter screen blockage.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Have you done any recent work on one of the axles such it might not be fully connected at the splines? (Long shot, I know.)
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
All the above + too low fluid will cause the car not to move - however since you can't drive the car, you can't measure the fluid because it can get warmed up enough to get a good lecture
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
That is not true.
You can check ATF level with engine OFF and COLD.
I posted the trick in forum, you just need to know where on the ATF dipstick to look at.
Post by cn90 »
O.O.
Year modwl mileage?
I see this every day...people post messages to get help and yet the most essential info such as year, model and mileage is rarely posted? Maybe we can read people's mind?
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
Yeah cn90...people panic when they breakdown. Year make and mileage are essential. You know they could have a broken passenger side axle. That happened to me on my 1997 850 R wagon...
