IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
RH high beam dead Topic is solved
greg850r
Year and Model: a long list
Been thanked: 11 times
RH high beam dead
Post by greg850r »
This is the 96 wagon I worked on forever for no spark and finally got it to run. I did a light check and the passenger high beam was out. I figured no problem, I have bulbs and put one in it. No dice. Ohmed the old one and it was good. Then I saw someone had been in there and there was electrical tape the length of the high beam wires in the housing. Again, no problem, off to the barn for another RH headlight housing. Installed and no joy either.
Then the headlight switch came apart as I was removing it from the dash do I grabbed another from a 95 parts car thinking I had found the problem. Ha! No such luck. Then I noticed a difference that caused me to go get a switch out of a 96 dash (see below).
I'm now chasing wires and a full check identified the blue wire with a white lead on the passenger side headlight plug as dead (Powers RH high beam). I pulled the fuses (19, 20) for the high beams and discovered continuity between each high beam wire at the headlight and it's respective fuse socket, yet only the driver's side high beam wire has 12 volts when I turn them on.
Oh well, guess I won't get this one inspected today.
There is a dip switch on the back of the headlight switch in the dash and the 95 is set to position C whilst both 96s are set to position A. A big wasp nest with attendant nasty flying things discouraged me from pulling the one out of the 97 dash to look at it.
Headlight switches.jpg (139.61 KiB) Viewed 115 times
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
Parts cars not included
greg850r
Re: RH high beam dead  Topic is solved
Post by greg850r »
I may have found out why I've been chasing my tail on this one so long with electrical problems.
While fiddling with the fuses I noticed the bad high beam winking at me. It does not appear to be the fuse connection but the spade connector inside the fuse box that plugs in to the underside of the fuseblock. I pushed down hard on one side of the fuses and now the light works. Leaves me wondering how many others are intermittently losing connection.
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
Clemens
Has thanked: 97 times
Been thanked: 57 times
Post by Clemens »
Greg, your posts make my wake up at night in horror of what could go wrong on my p80ies... Seriously. I hate electrical gremlins. Thought we are well off, but your storeis make me wonder...
Glad you found the root, though.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
wizechatmgr
Has thanked: 24 times
Been thanked: 63 times
Post by wizechatmgr »
Those are the type of problems that give me a headache. Glad to hear you tracked it down =)
They also make RF injector/tracers to find shorts and broken wires. Bit expensive for the hobbyist but most definitely something a serious shop would want to own if they do electrical often.
1999 V70 XC AWD - ~193k miles
greg850r
Post by greg850r »
wizechatmgr wrote: Fri Jul 12, 2019 7:08 pm They also make RF injector/tracers to find shorts and broken wires. Bit expensive for the hobbyist but most definitely something a serious shop would want to own if they do electrical often.
Toners are nice and I've used one, but it was borrowed to troubleshoot old wiring in a house. Not wanting to spend the money on one, I've since come up with an alternative. A cheap ohmmeter with an alarm that beeps on continuity works great in it's place. You may need a piece of wire so it reaches where you need the probe to go. On the house job I carried a hundred foot roll of signal wire to make my connections. On the car an extra 10 feet usually will suffice.
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 376 times
Been thanked: 1176 times
greg850r wrote: Mon Jul 15, 2019 8:38 am
You can adapt a circuit tracer for home use (pretty cheap) with wire and a slip on connector or probe - ground the fat side, then detect with the detect tool
You still have to know some circuitry to isolate stuff though, its not idiot proof, or even dullard proof.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
