Tip/Trick: Wheel mounting alignment tool.
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
Tip and/or Trick:
All of my Volvos except my 1999 S70 have had a place on the wheel where the pin on the rotor could engage and line up the lug holes properly. The stock 99 S70 wheels have no provision for accepting the alignment pin. A guy at a tire store gave me an aluminum alignment tool that is threaded on one end and rounded on the other which works just fine - when I can find it...
I used to have to mount heavy x-ray tubes to overhead gantries that had four bolts in the back. Once you got one bolt in, the other three were easy, but that first one was a real bitch to get started while holding a 70 lb weight at chest height. A more experienced guy showed me that you could take a slightly longer standard bolt and grind the head off to make an alignment tool. You thread that in finger tight, hang the weight on it, align the other bolt holes, install the other bolts, and then remove the alignment tool and replace it with the last bolt.
I was going to get a long bolt the same thread as the lug nut and cut the head off, but the tire guy did me a favor by handing me the exact tool. If no one hands you such a tool, I suggest making one. You might want to chamfer the edges where you cut the bolt head off.
All U.S. market models.
All running and on the road.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
And when you consider that on a P80 the "alignment pin" is basically useless even when there *is* one, this is a great tip. With a large fleet and all of their tire rotations and snow tire changes, I remove and remount a lot of wheels. Feels like sometimes I have work too hard to align the holes.
P80 wheel lug bolts are M12 x 1.75, take that info to the hardware store or consider it if you want to buy something prefab like https://www.amazon.com/Steelman-78820-1 ... way&sr=8-1
Has thanked: 1610 times
Been thanked: 4068 times
I bet you can buy that bolt in Chinesium SS from Lowe Quality with an unthreaded shank, and you can just snap off the head with your fingers.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
abscate wrote: 12 Jul 2019, 19:39 I bet you can buy that bolt in Chinesium SS from Lowe Quality with an unthreaded shank, and you can just snap off the head with your fingers.
Or I can hit it with a torque spec that should be in inch pounds and instead do it in foot pounds =P
Post by erikv11 »
wizechatmgr wrote: 12 Jul 2019, 20:02
Video, please!
wizechatmgr
erikv11 wrote: 12 Jul 2019, 20:37
Video, please!
Sadly, the bolt in question was through a cam bearing cap - suffice it to say that bad boy suddenly went loose then blam, snapped and the torque wrench jumped. Had I been counting the number of turns, I would have likely known better. Of the 12 bolts torqued, only one failed.
Rear left below...
This was on a 2012 Ninja 650, the access to that area to remove that snapped bolt SUCKS. Looking like I'll be using Alum to eat the steel out.
Eddystone
Post by Eddystone »
Or $2.53 at Home Depot...
Eddystone wrote: 12 Jul 2019, 21:10 Or $2.53 at Home Depot...
How much of a discount can I get if they cut off the head?
wizechatmgr
abscate wrote: 12 Jul 2019, 21:39
That used to be a thing with failed leadership =P
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Buy it at Lowe's or Home Depot and then go to lumber and ask for that 1 free cut you are allowed
