Did you know? 🤔
Coolant low prompt on DIM Topic is solved
2001 - 2007 XC-70
MDK
Year and Model: 1998 xc 70
Has thanked: 0
Been thanked: 28 times
United States of America
MDK
Post by MDK » Sat Jul 13, 2019 7:12 am
Low coolant prompt... not solved
Has thanked: 0
Been thanked: 131 times
Re: Coolant low prompt on DIM
Post by cn90 » Sat Jul 13, 2019 8:02 am
I hate to state the obvious but did you open the hood and check coolant level?
Every time a coolant reservoir is replaced, it takes some time for the level to settle down (air bubble).
Has thanked: 318 times
Been thanked: 986 times
Trinidad & Tobago
Post by abscate » Sat Jul 13, 2019 9:01 am
Hey all .. MDK here. So, the other day I changed out my overflow bottle and now I got the prompt on the Driver's information module. Did tell you all how much I hate computers on cars? I had swapped out the sensor, all the hoses and the cap. I didn't even unplug it.. just popped out and popped it into the new one... very carefully. Put the $π|∆ all back together..re-fill.. check for leaks, started it up and bam ==°¥¥°{×{¥π={¶ CODE!! AHH! I know that the sensor is factory.. maybe by just disturbing it I might have damaged it in some way..... now what do I do! Any thoughts ??
Which car is this on? Its easy to damage those sensors if you tug on them when replacing the bottle, and they fail in a mode that triggers the low coolant warning (a good design)
Link To Volvo Glossary
oragex
Year and Model: S60 2003
Has thanked: 95 times
Been thanked: 267 times
Canada
oragex
Post by oragex » Sat Jul 13, 2019 9:54 am
As above, if for some reason we need to lift the coolant reservoir (sometimes along with the P/S reservoir for work at the timing belt, etc), just slightly pulling on the sensor cord can make it to fail - even if nothing looks broken. This is why I always unplug the sensor first, then lift the coolant tank. The connector is sandwiched between the ECM box and the wall. Same goes with ABS sensors, just a slight pull on the wire near the sensor and kaput
A used sensor from the junkyard should do the trick
Also check the float inside the reservoir, sometimes it may get stuck at the bottom
MDK
Has thanked: 0
MDK
Post by MDK » Sat Jul 13, 2019 11:06 am
Thanks Oragex... that's probably what has happened. Even as careful as I was. The reservoir is full cold...I unplugged it and did a continuity test and the circuit seems to be open. I guess I need a new one. 16$ from IPD. I'm going to go plug in my VIDA and see what I can see... thanks guys... really appreciate you taking the time to read my post...
MDK
Has thanked: 0
MDK
Post by MDK » Sat Jul 13, 2019 1:24 pm
So I hooked up my VIDA and really didn't get a read out on the level sensor however..did get a read from the fuel pressure sensor... signal too high. So I guess I need to get that to from my friends @ IPD... RRRRR
Trinidad & Tobago
Post by abscate » Sun Jul 14, 2019 7:48 am
Clear that code and monitor - there is no reason to replace parts based on codes if the car runs well.
