04 s80 2.9 non turbo starts then stalls. Will stay cranked if given throttle.
04 s80 2.9 nonturbo starts then stalls. Will stay cranked if given throttle.
- SuperHerman
- Been thanked: 207 times
Any codes? Lights on dash?
Throwing out an easy one - pull the MAF connector and see what happens.
Pulled maf plug nothing happened. Traced wires found splice,reconnected 2 that had come undone. Tried again and it stalled. Maf good now but still stalls when not given throttle then will idle until it gets to temperature then it starts spitting and sputtering and goes into limp mode.
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Sounds like a vacuum leak somewhere? Trace all the work and surrounding area to see if you didn't put something back or caused a hose to crack.
- MoVolvos
Have you tried cleaning the ETM?
- MoVolvos
Here is a quick checklist on rough running to stalling engines
- MoVolvos
Did either make any difference or did the problem start after you installed one or both?
