Smoking dipstick, could it be bad rings?
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 43 times
Post by callahanoffroad »
Because I've put so much money into Herman over the last two months I felt like I should double check the compression numbers and make sure that Herman's engine was as healthy as all his other systems...
A quick refresher, Herman is a 1994/5 Volvo 850, non-turbo, with a manual transmission.
Pulled these compression numbers tonight with a hot engine:
Dry Run
  • Cylinder 1: 180 psi
  • Cylinder 2: 185 psi
  • Cylinder 3: 195 psi
  • Cylinder 4: 175 psi
  • Cylinder 5: 183 psi
After these numbers I did a wet compression test by adding about 1 tbsp engine oil into the spark plug tubes... PS Don't do that all at once... Just one at a time. It is quite messy.
I could only pull one number and that was Cylinder #1 which had a compression of 210 psi.
What what does the brain trust think? (That's you by the way.)
I'm thinking I need new rings, or a new to me low mileage engine.
I've been looking for new rings but I can't find them for the NA engine. Looks like they may not make them anymore? :lol:
This also explains the severely smoking dipstick and head.
Last edited by callahanoffroad on Tue Jul 16, 2019 5:38 am, edited 1 time in total.
ZionXIX
Has thanked: 9 times
Been thanked: 46 times
Re: Smoking Dipstick, oh its just bad rings!
Post by ZionXIX »
Those are excellent compression numbers. If you're worried about a smoking dipstick, I would look at the pcv again. Maybe drop the oil pan and do a thorough cleaning, inspection and replacement of any clogged parts. But that's just me, it's on my list anyway.
Has thanked: 378 times
Been thanked: 1182 times
Im running very low compression measured in my T5 - I think under 150 psi
here, even worse than I remembered
Cold compression test was low to spec, but spec is warm
I showed 125-135 psi across all cylinders, spec is..
NOTE: Measure compression with the engine hot and at wide open throttle
Normal value B5234T and B5254T: 1.1-1.3 MPa (156-185 psi)
Maximum deviation between cylinders: 0.2 MPa (28.4 psi)
NOTE: This applies when the engine is warm and the throttle fully open and the engine being turned by the starter motor at 4.2-5.0 rps (250-300 rpm).
I use about 1 liter of oil per 2500 miles, and have good pep and fuel mileage.
Run it till the cows come home....
Link To Volvo Glossary
callahanoffroad
1993-1997 850 Non-Turbo: 185-213psi is spec according to FCP Euro's blog:
https://blog.fcpeuro.com/how-to-do-a-co ... nder-volvo
greg850r
Year and Model: a long list
Been thanked: 11 times
Post by greg850r »
I have 160 or so in all mine and they run great and don't use oil. Your problem lies elsewhere.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
Parts cars not included
Has thanked: 112 times
Been thanked: 327 times
Those numbers look good for a 200k NA engine. Nice tight grouping too, healthy bottom end.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'99 Camry V6 :shock: 130k
Clemens
Has thanked: 97 times
Been thanked: 57 times
Post by Clemens »
As others said: Great numbers, very little difference, don´t worry!
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
callahanoffroad
Re: Smoking dipstick, could it be bad rings?
Thanks for the input everyone.
Looks like I'm back to the pcv system... Again...
I really have half a mind to just replace all the tubing with pcv filters. Unfortunately it makes the car stink like you wouldn't believe.
Maybe I could rig a small air pump to suck the fumes out...
Clemens
Post by Clemens »
Be sure to make the large diameter hose mod (you replace the palstic line with a regular oil proof rubber fuel line (I know rubber isn´t oil proof, but you get the idea) and run it to the ptc valve. After doing that, I finally got good vacuum. I´d go so far not even to touch anything else but replace just that hose if you had done the PCV recently.
(The theory is that with worn rings at 200.000 miles the blowby is too much to get sucked out of that plastic tube efficiently)
Summer: 1996 855 R
Donor: 1995 854 10V
greg850r
Post by greg850r »
Did you clean out the passage in the bottom of the block when you had the PCV box off? They usually clog up inside the block where the bottom of the breather box mates to the front of the motor. I use copper A/C refrigerant line to replace the big hose. I just take the new elbows and the insulating cover off that hard plastic one they give you with the kit and throw it away.
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
