96 850T check engine light on but no codes
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
I thought the check engine light indicated a fault code but several attempts all result in zero codes found. Should I get a different reader? The only thing wrong with it is it's from Harbor Freight.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
Has thanked: 2197 times
Been thanked: 1851 times
I'm not sure how well these readers read the early Volvos. As a 96 I believe it no longer has the under hood code reader. There are several items on MVS on how to build a basic code reader with cheap components using an LED bulb.
Has thanked: 1609 times
Been thanked: 4064 times
It might be a Volvo Code P1xxxx that the reader can't map. If the light is on, a code is stored.
Make sure the B+ voltage is good and tight
:D
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
If the car have auto transmission it could be request from TCM to turn on check engine light and that can ONLY be read via special Volvo scan tool...at least VOL-FCR.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Klausc
Year and Model: 1995 855 Turbo
Been thanked: 15 times
Post by Klausc »
Stop by an auto parts store and ask to use theirs. Most chains let you do it for free.
Klaus
