My low beams have always been adjusted as high as they will go. I do not use the car much and recently I see that the low beams have dropped quite noticeably. Checked the adjuster and both are at their max height. Very weird. The beams used to be quite a bit higher. But somehow seem to have dropped. No front end damage etc.
Any ideas? Cannot see very far now!!!
Low beams, really low!!!
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Are the bulbs placed correctly in there ? It is relatively easy not to seat them correctly which will cause them to sit at an angle. I'm assuming you have the glass cover headlights ? Also, when the bulbs get older they get dimmer www.youtube.com/watch?v=IbZqhIyS1as
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
If they both all of a sudden became low that shouldn't be it though.oragex wrote: 17 Jul 2019, 14:18 Are the bulbs placed correctly in there ? It is relatively easy not to seat them correctly which will cause them to sit at an angle. I'm assuming you have the glass cover headlights ? Also, when the bulbs get older they get dimmer www.youtube.com/watch?v=IbZqhIyS1as
Ducatiguy
- Year and Model: 2004 XC70
- Has thanked: 1 time
Thanks all for the replies. Bulbs are fine. It certainly seems it is the auto leveling system. I understand there are two sensors that signal the brain regarding the level. The motors work when engaging the high beams. So does this mean one or both sensors are bad? If so where are they located and how much work is it change them. I don't mind some DIY repairs.
It’s crazy how complicated these things get. I guess it’s better than having a person walk in front carrying a lantern.
Ducatiguy
Excellent. Thank you.Any photo or diagram around possibly?Rattnalle wrote: 17 Jul 2019, 23:54 P2s only have one sensor afaik. It's located on the rear link arm halfway in. Easy to both see and reach.
- 798 Views
Last post by T64me
- 625 Views
Last post by mandkbean
- 711 Views
Last post by JimBee
- 603 Views
Last post by cjrayburn1
- 2411 Views
Last post by jh_on_the_cape
