Did you know? 🤔
2002 S80 NA will not run longer than 10 seconds
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
Drdave007
Year and Model: 2002 s80 2.9l non tu
Has thanked: 0
Been thanked: 0
United States of America
Drdave007
Post by Drdave007 » Wed Jul 17, 2019 10:49 am
got this 2002 s80 very cheap because no one could make it run, I think i am a competent technician, has fuel pressure 55-60psi,
injector pulse good,swapped injectors,ignition firing on all six coils, timing belt in time and hasn't been messed with. will run for ten seconds then sounds like it leans out, spraying carb cleaner makes it worse but plugs not fouling. if you grind on starter it will almost crank sometimes but sounds like its a tooth out in timing or real slow. compression 100 pounds . any ideas???? all help am very thankful for.
Reason: improved title
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 36 times
Been thanked: 76 times
MoVolvos
Re: will not run!!! help
Post by MoVolvos » Wed Jul 17, 2019 10:10 pm
compression 100 pounds. any ideas???? all help am very thankful for.
Well Doc?
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
Drdave007
Has thanked: 0
Been thanked: 0
Drdave007
Re: 2002 S80 NA will not run longer than 10 seconds
Post by Drdave007 » Thu Jul 18, 2019 10:09 am
lower timing pulley getting checked next. would explain compression off
Drdave007
Has thanked: 0
Been thanked: 0
Drdave007
Post by Drdave007 » Fri Aug 30, 2019 9:35 pm
nope still doesnt run
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 26 times
Been thanked: 27 times
Netherlands
ndphotonl
Post by ndphotonl » Sun Oct 27, 2019 2:57 pm
Try a new crankshaft sensor would be my first idea.
MAF ok?
Precat O2 sensor ok?
Did you do a scan with DICE?
Volvo S80 2.4T Wasa Limited Edition
Blog / FlickR / YouTube channel
SuperHerman
Has thanked: 0
Been thanked: 163 times
SuperHerman
Post by SuperHerman » Mon Oct 28, 2019 10:30 pm
On my old 2004 S80 2.9 NA that I gave my sister, after much digging and searching her problem was a clogged CAT.
Try taking out an O2 sensor and having a look - maybe a couple of well placed rubber mallet hits to listen for honey comb issues.
Year and Model: Lots
Has thanked: 4 times
Been thanked: 110 times
Australia
Post by precopster » Tue Oct 29, 2019 6:18 am
Which engine is fitted? Turbo or non? 100psi for a non turbo is almost a dead slug.
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
Has thanked: 363 times
Been thanked: 1109 times
Trinidad & Tobago
Post by abscate » Thu Nov 07, 2019 3:21 pm
Spec 150-180psi
Its dead, Jim.
Link To Volvo Glossary
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 617 times
Been thanked: 258 times
matthew1
Post by matthew1 » Thu Nov 07, 2019 4:10 pm
"I'm a doctor not a Volvo tech!"
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
SuperHerman
Has thanked: 0
SuperHerman
Post by SuperHerman » Thu Nov 07, 2019 8:35 pm
I am not so quick to call the engine dead because of the compression test. You have to eliminate a few items. First put a half of a cap of oil in each cylinder spark plug hole with all the plugs out - cover the holes with a rag thrown on top. Spin the engine a few times then let it sit a few minutes and redo your compression test. Your numbers may be low because the engine has not run in a long time. Worth the time to see if you can get the numbers up before calling it dead.
Miles on the motor and condition of the oil? Did you change the oil? It could be full of gas causing your problem with compression. Drain oil and look for metal sparkle, a sign of mechanical issues.
Unfortunately you have no history on the car as it would have shown signs of compression lost. Do what follows before you try adding oil as it will cause a false positive. You first have to look for signs of burning oil.
Visually inspect the exhaust tip for soot (sign of oil burning) and the spark plugs. Then shine a light down and inspect the piston tops, but do this after you have the plugs out for about an hour so any unburned gas can evaporate.
Report back, but I would also look at your exhaust pressure as I mentioned before.
I am not a doctor nor a Volvo mechanic, but McCoy was.
