Hello:
Recently experiencing vapor lock when the temps are high. Typically, I just have to wait for things to cool off––but this is increasingly taking upwards of 6 hours.
Thoughts, comments, recommendations?
S70 T5 Vapor-lock when Hot
VolvoAffair
- Year and Model: 1998 S70
- Been thanked: 4 times
vovo850
- Year and Model: 1995 850 glt
- Has thanked: 49 times
In the carb days we would add a wooden clothespin to the fuel line.
Add a spacer to the carb, insulate the fuel line.
Some would add a electric fuel pump to help.
Which leads me to say that seems really odd, is your fuel pump good?
Because I never heard of vapor lock in a fuel injected engine.
Edit to add I should have added fuel relay, it may be going bad, getting hot and failing. It also would not allow a restart until it cools off. Might be closer to a vapor lock symptom as well. That is fairly easy to test, just swap the relay out.
1995 Volvo 850 GLT N/A automatic wagon
- Has thanked: 311 times
- Been thanked: 817 times
What he said - it's not vapor lock. Start by testing the fuel pump relay (jumper it), then the fuel pump.
- Has thanked: 316 times
- Been thanked: 531 times
I've heard of these symptoms in 240s, but never a P80. Is your fuel pump running? What's your fuel pressure at idle?
+1 on the fuel pump relay, those are common failure items. It's very possible that it's overheating and failing.
