S70 T5 Vapor-lock when Hot
VolvoAffair
Year and Model: 1998 S70
Been thanked: 3 times
Post by VolvoAffair »
Hello:
Recently experiencing vapor lock when the temps are high. Typically, I just have to wait for things to cool off––but this is increasingly taking upwards of 6 hours.
Thoughts, comments, recommendations?
vovo850
Year and Model: 1995 850 glt
Has thanked: 44 times
Re: S70 T5 Vapor-lock when Hot
Post by vovo850 »
In the carb days we would add a wooden clothespin to the fuel line.
Add a spacer to the carb, insulate the fuel line.
Some would add a electric fuel pump to help.
Which leads me to say that seems really odd, is your fuel pump good?
Because I never heard of vapor lock in a fuel injected engine.
Edit to add I should have added fuel relay, it may be going bad, getting hot and failing. It also would not allow a restart until it cools off. Might be closer to a vapor lock symptom as well. That is fairly easy to test, just swap the relay out.
1995 Volvo 850 GLT N/A automatic wagon
Has thanked: 112 times
Been thanked: 327 times
What he said - it's not vapor lock. Start by testing the fuel pump relay (jumper it), then the fuel pump.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'99 Camry V6 :shock: 130k
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 45 times
Been thanked: 182 times
Post by bmdubya1198 »
I've heard of these symptoms in 240s, but never a P80. Is your fuel pump running? What's your fuel pressure at idle?
+1 on the fuel pump relay, those are common failure items. It's very possible that it's overheating and failing.
'00 V70R Venetian Red/Charcoal M56 Swapped 199k
'03 S60 2.4T Silver/Black 117k
'07 XC90 V8 AWD Sport Titanium Grey/Black 174k
'91 944 Turbo Dark Green/Beige 175k
'92 245 Base White/Beige 249k
'99 BMW 528i
'01 Mountaineer 5.0
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
