Hey all,
I have a 2007 Volvo S60 with a wiring harness that's seen better days.
I have an ad posted for a replacement but I'd rather try to fix it the cheapest way possible so I can get up and running again. It doesn't have to last forver.
Here are the issues:
I have a lot of ideas for fixing it but I don't know where to start. Can I just use tape on the areas away from the coil connectors? What do I do about the wires that are degraded immediately outside of the coil connectors?
Also (not pictured) I cut the 5 white and green wires rather than the 1 bigger composite wire that they all join to when I got the piece out from the engine bay. This was a rookie mistake. Anyway would it be easier to solder it back into the car, or use butt connectors?
Thank you in advance for any advice!
How do I repair this wiring harness? (S60)
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Wiring Loom / Harness - High Temp
https://www.amazon.com/225FWY-Conduit-P ... way&sr=8-6
03 S80 T6 - I've recently used the tape to clean up the wiring for the H7 headlight wires. Like yours the plastic had crumpled and are bare.
You can use the tape on the outside of the Loom / Harness to keep the wiring in. Just a few wraps every 6 inches or where there is a bend or at the Y.
However, it was mostly used in the center console to quiet squeaking plastic. Removed the entire center console and taped everything so it does not squeak anymore.
Tesa 51608, 25m x 19mm adhesive wiring cloth tape original ISOBAND 3 pcs pack
https://www.amazon.com/gp/product/B00XP ... UTF8&psc=1
If you can remove the wires from the plugs it is much better than the tape above. This has a glue in the center to hold the wiring tightly together.
270pcs 3:1 Dual Wall Adhesive Heat Shrink Tubing Kit, 5 Sizes (Diameter): 3/8, 1/4, 3/16, 1/8, 3/32 inch, Premium Wire Cable Sleeve Tube Assortment with Storage Case for DIY by MILAPEAK (Black & Red)
https://www.amazon.com/gp/product/B0771 ... UTF8&psc=1
- MoVolvos
Check out the wiring harness pictures. Click Customer Reviews.
https://www.amazon.com/gp/product/B00XP ... merReviews
- 14 Replies
- 4642 Views
Last post by CIK7
- 5626 Views
Last post by gnalan
- 790 Views
Last post by oragex
- 2195 Views
Last post by Goldchemist
- 666 Views
Last post by rspi
