Did you know? 🤔
1995 850 Turbo - Radio Plug Question
noev70t5
Year and Model: 1995 850 TURBO
Has thanked: 0
Been thanked: 0
United States of America
noev70t5
Post by noev70t5 » Sun Jul 21, 2019 7:04 pm
Hi guys hoping to get some incite before I have to go out of my way to a salvage yard to rip apart an 850...
Ultimately this is my fault.
My 1995 850 has a SC-816 Radio I put into it, but the car only has 3 main connectors in the back. One big plug with about 8ish wires, small plug with about 6-8ish wires, and a solid black connector with a single metal tip. Someone tried to put an amp that would mess with my other electronics so I figured id try to fix it. After looking at a few diagrams it seems that they had tapped into a consistent power wire for the radios anti theft - and while rewiring it, that wire touched the single black wires connector and I could see it was shocking it. Being arrogant my dumb*ss thought I could do simple quick connects without messing up...
I'm not getting power to my radio now. Everything else works well.
Question: How far do I have to go to get to the other side of the Big plug on the radio harness? What does it ultimately lead back to?
Attached is the wiring diagram: I'm talking specifically about 16/1 - Plug A - Wire #4 (R-SB) [Red and Black]
I want to find the other side of plug A so I can not only check for further damage but to replace that whole section of wiring - When searching I only see things about replacing the plug on the radio side, Id like to aim for replacing the whole thing
Thanks for any info!!
96 854 Radio Component Locations, no amp.pdf
Specifically 16/1 - Plug A
(214.5 KiB) Downloaded 22 times
2002 s60 Base - 215k - KIA [08-2014]
2000 s70 Base - 170k - Traded in [2015-16]
1998 v70 t5 - 232k - KIA [2016-2018]
2000 s70 Base - 180K KIA [2018-2018]
1995 850 TURBO - 77K [2019-]
noev70t5
Has thanked: 0
Been thanked: 0
noev70t5
Re: 1995 850 Turbo - Radio Plug Question
Post by noev70t5 » Mon Jul 22, 2019 9:39 am
No surprise on no reply ONLY because I've NEVER seen the answer on pictures ect. I'm headed to the pick n pull now. I'll post pics soon
noev70t5
Has thanked: 0
Been thanked: 0
noev70t5
Post by noev70t5 » Mon Jul 22, 2019 4:28 pm
AWESOME lots of learning today.
If your constant power wire behind your radio (black and red wire**) ever touches the antenna wire while doing a wiring job and it grounds no need to worry!!!
Just check the RIGHT fuse. There are apparently 2 different radio fuses on a 1995 850. 32 and like 7. CHECK THEM BOTH
I ripped a plug out of the salvage yard but while I was there I tried to snag the whole harness. DAMN that was alot of work.
Endgame to all of this was that I blew a fuse while working and ended up rewiring everything for no reason. Lesson learned!!!
