Trailer lighting wiring
thienle
Year and Model: S80 2001 nonturbo
Post by thienle »
Can someone show me how to wire up a trailer lighting. The fuse panel locate in the truck left side has a fuse said for trailer (20A) and three spare electrical plugs. Are there plug use for trailer lighting? Thank you very much.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
I think you'll need a kit first?
https://www.etrailer.com/t1-2001_Volvo_S80.htm
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
That is a good kit. That car and almost all late model cars have electronics involved in the lighting that stops the old Scotchlok splice method from being used. The light module in the kit uses a power input to run trailer lights and the tap into the tail light wiring is a minuscule current signal to signal module to activate the out for the trailer light feed.
