Drain/relieve fuel prior fuel filter change? Topic is solved
Mikele82
Year and Model: XC70 04 + C30 T5 08
Has thanked: 30 times
Been thanked: 3 times
Post by Mikele82 »
is this a necessary step on a volvo 2004 xc70 (image attached) ?
i want to replace it myself but wondering how much fuel am i expecting to see coming out the hose once i unplug the old filter...
should i do it outside of my garage?
DrDan
Year and Model: 02 V70
Been thanked: 9 times
Post by DrDan »
Relieving the pressure is advisable. You will probably still spill fuel but it will be less. Working in a well-ventilated area is a good idea too, as the benzene in the fuel is carcinogenic. You want to inhale it or have it on your skin as little as possible. For that same reason, wear gloves.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I have replaced a lot of fuel filters and rarely de-pressurize the fuel. Interestingly, very little fuel spray when the hose is disconnected.
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
This procedure is recommended in VIDA when replacing the fuel filter. Here's Volvo's specific wording which is very slightly different from the above, in that they say to start the engine before removing the fuse:
Start the engine.
Remove the fuel pump fuse. Placement may vary between engine types and model year. See the Owner's manual or wiring diagram.
The engine will stop after approx. 20 seconds.
Turn over the engine 3-5 seconds.
Switch off the ignition.
Replace the fuse.
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
Post by cn90 »
I recently replaced the fuel filter on my 2005 XC90 2.5T with 100K miles...
- I did not de-pressurize the fuel.
- I just disconnect the hose, just when the hose is about to come out of the nipple, I place a rag.
Very little fuel comes out, it does NOT spray as people are afraid of!
- Of course have a container to catch spilled fuel.
- Once everything is installed, I turn the key to position II (do not start engine yet) to prime the fuel filter. Repeat this a few times, then start engine, it works every time.
- I am too old to remove the fuse and de-pressurize the system. Over the years, I found out it makes no difference anyway.
So I skipped that step of de-pressurizing the fuel system.
Has thanked: 1609 times
Been thanked: 4064 times
What does this really mean?
:lol:
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
I always thought the Volvo recommended procedure was a bit over-kill. If you want to release any residual pressure it’s easily done by spraying the fuel rail Schaefer valve into a rag.
Post by cn90 »
Abscate,
This means I am old.
But "old" comes with wisdom and experience.
There will always be "Textbooks" and there will be "Shortcuts", no matter what field (auto repair, dentistry, medicine, engineering) you are in.
