With the VIDA/DICE are the normal maintenance reminder intervals modifiable, and/or can they be reset vie VIDA/DICE?
Thanks
VIDA/DICE functionality
wanderdüne
- Year and Model: 2004, 2006 XC90 2.5T
- Has thanked: 6 times
- Been thanked: 45 times
Yes, they can be reset with VIDA/Dice, not sure if one can modify the interval or not. Why would you want to change the interval?
5ft24
- Year and Model: 2005 XC90 V8 AWD
- Has thanked: 20 times
- Been thanked: 12 times
Want to at least check the interval. I do the reset procedure with the trip reset button, it clears the message, I get the beep from the cluster, but the t1 mileage never returns as others say it should, and anywhere from 2-4 days later the normal service reminder comes back. Absolutely no trouble codes found in any of the modules with VIDA/DICE
5ft24
so read parameters from the DIM. Service interval was "Invalid Value", as was engine run time for service and Mileage interval for service.
set those back to default values, so now we see if the message stays gone
- 1390 Views
Last post by Matty Moo
- 15 Replies
- 2450 Views
Last post by insession
- 16080 Views
Last post by xiaofei204716
- 18897 Views
Last post by jonesg
- 7033 Views
Last post by Klem
