I recently acquired a 2007 XC AWD and it came with LED headlights.
However they suck or are damaged because they Low Beam warning comes up. I went looking for replacement options, but was inundated with options.
So I come to you folks for suggestions, what LED headlight kits do you use.
What LED headlights do people use in their Volvo
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
That's normal with these. They (LEDS) draw such little amperage when running the car sees this as no power is being consumed, thus the message for a failed bulb in the message center. We have LEDS in our 06 & they are excellent. I don't recall the brand, they are anodized red & have a cooling fan, maybe $40 on Amazon. The message that you have a beam out becomes less and less annoying. Most companies/sellers will comp you a set of resistors if you complain about the car giving you erroneous messages about failed bulbs. Listen further though.
The cool thing about leaving them alone (Not installing inline resistors) is that when you click on your highs, your lows ALSO remain on. All you have to do to clear the failed beam message is hit the "Read" button on the end of the turn signal stalk.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
Can't speak for a Volvo, but I've installed Hikari LED's on my daughters
Mazda 6 about 18 mos. ago and are still working well. They are very bright. Whatever brand you choose get the CAN BUS resistors with them. Some come with them built in others are just an inline connector you add. Good Luck
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Low beams aren't going to work when it comes to beam pattern. It seems to be very hard to actually reproduce a halogen bulb well. Highs aren't checked by the car so you can put anything in there.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Way too many Brands. You just have set a budget and find a seller on eBay or Amazon that has good ratings and read the 1 Stars. I always read the 1 Stars to see if there is a pattern of defects and if the customer service was responsive or poor. So far I've purchase cheap ones that had good rating and only 1 set have lasted about 2 years.
Will update after installing these on the 2003 S80 T6.
https://www.amazon.com/gp/product/B07HQ ... UTF8&psc=1
NOTE:
eBay: Has some fail products but eBay has never failed to step in to resolve a problem.
Amazon: So far have not been taken advantage of.
So far only 1 set has been dim enough that no one has flashed their headlight from time to time. LED beam pattern just scatters. Don't have them on the Volvos yet but the 03 Odyssey is easy on LED's whereas the 03 Lexus eats a set about once a year. Could be that I run my headlights all the time.Rattnalle wrote: 26 Jul 2019, 12:11 Low beams aren't going to work when it comes to beam pattern. It seems to be very hard to actually reproduce a halogen bulb well. Highs aren't checked by the car so you can put anything in there.
NOTE:
- Rattnalle
Headlights are always on here aswell. it's mandatory plus I prefer not dying myself.
But I have OE HIDs luckily. 70' km since last change so it'll be time again before winter
- MoVolvos
Weren't the Swedes that started the daytime running light thing and later caught on and into law here in North America? I too have the HID's on the 08 C30 but I turn the light switch to parking lights during the day so the HID is off.
The T10 bulb in the high beam location is replaced with a high wattage LED so it's bright and sharper during the day and in the evening.
- Rattnalle
Been the law since the 70s I think.MoVolvos wrote: 27 Jul 2019, 21:03 -
I've got a can-extender around that will switch to fog lights during day for me if I bother to plug it in and repair the fog light that's broken.
- MoVolvos
I vaguely remember when it fully became mandatory on all cars built in the U.S. I just remember the NHTSA slowly requiring manufacturers to faze in the change.Rattnalle wrote: 28 Jul 2019, 14:14Been the law since the 70s I think.MoVolvos wrote: 27 Jul 2019, 21:03 -
What is a "can-extender" and how is that wired into the fog lights. It would be brighter for sure to run those as the DRL.
- Rattnalle
A little data box that hijacks the can network signals and adds to them in different ways.MoVolvos wrote: 28 Jul 2019, 22:36 What is a "can-extender" and how is that wired into the fog lights. It would be brighter for sure to run those as the DRL.
Reason: cleaned up multiple nested quotes
- 61 Replies
- 14360 Views
Last post by bmdubya1198
- 474 Views
Last post by rspi
- 3180 Views
Last post by callahanoffroad
- 705 Views
Last post by AlanS
- 22 Replies
- 4298 Views
Last post by PS78
