Here's a weird one. Of course the door dinger goes off like it should when the door is opened with the key in the ignition.
A new problem has started up that I don't like because that means something going on with the electrical system.
The one door chime now goes off when anything is opened.
Any door
Hood
Trunk
Glovebox
Light on Sunday visor
And a couple other components.
I need a 960 Green electrical manual. Any body have one or know how to get one from Volvo.
Also any tips appreciated. How about the ignition switch or the door chime switch.
Thanks Dave
Electrical issue on my '96 960
projectsmorol
- Year and Model: 2008 c30
What other symptoms are you having with the electrical?
2008 C30:
Darton wet sleeves|CP Carrillo pistons&rods|Upgraded injectors|K16 turbo|3"downpipe|ELEVATE:cat back|custom intake|turbo intercooler hard pipe|lower motor mount|turbo blanket|intake plenum|downpipe wrap|dual bypass valve|lowering springs|rear camber arms|do88 FMIC|Porche 70mm TB|BMC air filter|MAF upgrade|Turbosmart waste gate|meth injection|IPD brake lines|NGK iridium 1 step colder|APR head studs|AEM AFR/Boost Gauge|Hilton Tuning
dm635
- Year and Model: '96 965
- Been thanked: 14 times
clock is now running slow by about 10 minutes a day. Where it used to be dead on. Cruise now might work 1/3 of the time when setting. When it used to work 100% of the time.
96-964
09-V70
05-325i
86-635CSi
Previous- 83 245T, 84 242, 85 242T, 92 960, 94 960, 95-964, 95-945, 91-780t, 96-960, 98-XC, 91-745,
09-V70
05-325i
86-635CSi
- 521 Views
Last post by dm635
- 830 Views
Last post by Michaelxlindsay
- 1501 Views
Last post by dm635
- 4019 Views
Last post by WagonLagan
- 981 Views
Last post by chrism
