Hello everyone,
My 05 S60 AWD 2.5T is posting codes P0016 and P0017.
I changed the crank sensor and both cam sensors but the vehicle continues to post the codes. The car runs and performs as it should and there is no oil leaking on the timing belt so I do not think it has jumped time. Also the belt looks to be in fine condition so I do not believe it to be worn or stretched.
Any assistance or direction would be greatly appreciated.
2005 S60 CEL P0016 & P0017
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
From what I read about those codes, they apparently refer to the timing correlation BETWEEN the crank and cam(s) and not some much that the sensors are bad. How’s the condition and tension of the timing belt? Could it have slipped a tooth? Maybe a VVT servo issue? Just tossing out some ideas to get the forum’s thought juices flowing......
highmiles
- Year and Model: 2001 S60 T5
- Been thanked: 4 times
I agree that it sounds like a subtle timing issue. VVT solenoids need cleaning or just an oil change?
Pull timing belt cover and check the timing mark alignment.
Any recent work done?
- 752 Views
Last post by Liason
- 1855 Views
Last post by Tundra12
- 1758 Views
Last post by marcels
- 5194 Views
Last post by Goldchemist
- 1745 Views
Last post by daimyo
