Volvo xc90 2013 headlights come on randomly
rbarham
Year and Model: 2013
Has thanked: 1 time
Post by rbarham »
My 17 year old daughters Volvo XC 90 has been having the issue of headlights coming on randomly. If she hits a bump, uses turn signal the headlights come on. Also the car can be sitting in driveway parked for hours and I look outside and the lights are on. Any help on what this could be? Our closest dealership is 200 + miles. Thanks in advance
projectsmorol
Year and Model: 2008 c30
Post by projectsmorol »
Does it have daytime running lamps?
2008 C30:
Darton wet sleeves|CP Carrillo pistons&rods|Upgraded injectors|K16 turbo|3"downpipe|ELEVATE:cat back|custom intake|turbo intercooler hard pipe|lower motor mount|turbo blanket|intake plenum|downpipe wrap|dual bypass valve|lowering springs|rear camber arms|do88 FMIC|Porche 70mm TB|BMC air filter|MAF upgrade|Turbosmart waste gate|meth injection|IPD brake lines|NGK iridium 1 step colder|APR head studs|AEM AFR/Boost Gauge|Hilton Tuning
rbarham
Has thanked: 1 time
Post by rbarham »
it does have daytime running lamps
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 6 times
Been thanked: 45 times
Post by wanderdüne »
I'd unplug the switch just to see if it happens without it plugged in:
Otherwise, it is considered by many, myself included, to have a VIDA/Dice diagnostic unit especially if the dealer is distant.
The Volvo tool for diagnostic is called VIDA Dice. The VIDA is the software part and the Dice is the physical reader. VIDA contains all of the parts catalogs, repair procedures, diagnostic trees etc. You can download a "version" of it here https://forums.swedespeed.com/showthrea ... nload-Link to inform and educate yourself about what repairs you are getting done. You can buy a "cloned" Dice off of ebay or amazon to use so you can begin to suss out the electrical issues, diagnostics, clearing active and vestigial codes etc. by yourself. Pretty indispensable.
I pm'd you a link to someone (How I got mine) who can sell you a dedicated VIDA laptop pre-installed if you prefer that. You would still need to purchase a (cloned) or actual$$ OEM Dice unit
