Did you know? 🤔
Help with transmission fill bolt
2001 - 2007 XC-70
neworleans
Year and Model: 2007 S60R
Has thanked: 0
Been thanked: 0
United States of America
neworleans
Post by neworleans » Sun Jul 28, 2019 7:40 pm
Hello all,
I was planning to flush the transmission fluid on my 07 S60 2.5T and was really surprised when I saw this 5 point bolt because I was expecting a torx screw rather. First time I see a 5 point bolt on a Volvo. Do you all think this is original or it could be the previous owner changed it maybe after stripping the torx screw? Any idea what size of 5 point socket this is? Thank you.
Has thanked: 0
Been thanked: 121 times
Re: Help with transmission fill bolt
Post by cn90 » Sun Jul 28, 2019 7:55 pm
It is a good thing you ask.
If you ever remove that bolt, you WILL regret BIG time.
For my 2004 V70 2.5T:
Drain: 24-mm bolt.
Fill is via dipstick tube. I posted the trick using the long funnel (search forum).
neworleans
Has thanked: 0
Been thanked: 0
neworleans
Post by neworleans » Sun Jul 28, 2019 8:24 pm
cn90, thanks for your reply.
I also have a 07S60R and that one doesn't have a dipstick tube so I thought this one would also have a fill screw just like the R and I noticed this bolt :)
I just looked for the tube and located it. Thanks again.
Has thanked: 254 times
Been thanked: 809 times
Trinidad & Tobago
Post by abscate » Sun Jul 28, 2019 9:05 pm
Don’t touch that’s one!
Link To Volvo Glossary
chrism
Year and Model: S80 / 2005
Has thanked: 0
Been thanked: 20 times
chrism
Post by chrism » Sun Jul 28, 2019 9:55 pm
It’s a plane looking six point bolt on my 2003. I guess Volvo thought switching to five point would discourage some accidental removals.
Has thanked: 0
Post by cn90 » Sun Jul 28, 2019 10:04 pm
Volvo should have placed a label there stating "Do NOT touch", but they did not place the label.
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 26 times
Been thanked: 49 times
MoVolvos
Post by MoVolvos » Sun Jul 28, 2019 10:08 pm
IPD shows an 07 S60R has the TF-80SC AWD (6 Speed). The 2.5T has the AW55-5X.
https://www.ipdusa.com/
Volvopartswebstore.com shows a dipstick for the 07 S60 2.5T in their transmission diagram.
https://www.volvopartswebstore.com/show ... evel=24659
EDIT: TF-80SC AWD Trans Fluid Flush - Drain and Fill Method.
EDIT: Hose Flush - Fuller Replacement
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
MoVolvos
MoVolvos
Post by MoVolvos » Sun Jul 28, 2019 10:28 pm
Can't tell what year this is but it's the AW55-50 - VERY GOOD VIDEO!
DIY Volvo automatic gearbox flush AW55-50, MANNOL 3309 with oil comparision
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 31 times
EngineeringBloke
Post by EngineeringBloke » Mon Aug 12, 2019 1:03 pm
Just in case it was not made clear in the comments above. The bolt, which was changed to a specialized 5 sided bolt to discourage removal, is not for a transmission oil fill hole cover, but retains a ring within the transmission. When unbolted, the ring can rotate out of position and require transmission removal and renovation.
Fortunately, some have found a way to rotate the ring back without removal but I would not want to risk it:
viewtopic.php?t=79032
MDK
Year and Model: 1998 xc 70
Has thanked: 0
Been thanked: 28 times
MDK
Post by MDK » Mon Aug 12, 2019 3:52 pm
Not trying to be a wise guy here. But that 5 point bolt means that they don't want you to take it out. It holds the bands for the transmission in place... WARNING !WARNING! DANGER WILL ROBINSON DANGER!
