Did you know? 🤔
98 S90 ATF dripping from some hose
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
thefisch
Year and Model: 1998 S90
Has thanked: 6 times
Been thanked: 0
United States of America
thefisch
Post by thefisch » Sun Jul 28, 2019 8:38 pm
Noticed a few drops of ATF on the garage floor and then again a few days later on the driveway. Going to get the car on a lift later this week and inspected, but in the meantime I took a couple of pics from underneath the driver side.
It seems the fluid is dripping from the hose with the white clip in the photos below. Can anyone tell me what this hose is for? There is some fluid on the blue tape on the hose to the left. I realize that leaking fluid can travel in strange direction due to airflow, but this hose seems like an odd location. The transmission pan itself seems dry and didn't see anything dripping from it - it was resealed about 10 years ago.
RickHaleParker
Has thanked: 3 times
Been thanked: 358 times
RickHaleParker
Re: 98 S90 ATF dripping from some hose
Post by RickHaleParker » Mon Jul 29, 2019 8:21 am
Dope the ATF with Trace Dye. That way when you got it the lift, you can trace the fluid back to the source.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
projectsmorol
Year and Model: 2008 c30
Has thanked: 0
projectsmorol
Post by projectsmorol » Mon Jul 29, 2019 8:49 am
I concur with mr rick as these types of issues are nigh impossible to diagnose without physically being there with experience to see
the possibilities.
2008 C30:
Darton wet sleeves|CP Carrillo pistons&rods|Upgraded injectors|K16 turbo|3"downpipe|ELEVATE:cat back|custom intake|turbo intercooler hard pipe|lower motor mount|turbo blanket|intake plenum|downpipe wrap|dual bypass valve|lowering springs|rear camber arms|do88 FMIC|Porche 70mm TB|BMC air filter|MAF upgrade|Turbosmart waste gate|meth injection|IPD brake lines|NGK iridium 1 step colder|APR head studs|AEM AFR/Boost Gauge|Hilton Tuning
thefisch
Been thanked: 0
thefisch
Post by thefisch » Mon Jul 29, 2019 10:36 am
Appreciate the responses. That is a great idea.
Incidentally, I looked further back on the car and think the 'hose' in the picture is actually sheathing for a cable to an emissions sensor. On the rear side of the bracket for the rear transmission mount (which the cables pass over that bracket in the photo), these cables then cross over to the passenger side going under the tail end of the transmission and drive shaft. Then they continue on the passenger side and connect to sensors in the exhaust. So for ATF to get on them, perhaps it is leaking from the tail end of the transmission onto the sheathing and then running to the lowest point.
projectsmorol
Has thanked: 0
projectsmorol
Post by projectsmorol » Mon Jul 29, 2019 11:32 am
Unfortunately, you are only going to get speculative answers here or any other blog/forum. A "leak" is on an individual bases. Everybody has a different circumstance. Leaks come from different places at different times on different days from different temps etc.
If you have the ability, you are best to wipe everything down with a microfiber to make SURE it's clean, run the car to temp to heat/expand the fluid to cause the leak and then look to see where it originated. Option two, put contrast/dye in the tranny fluid and see where it's coming from.
2008 C30:
thefisch
Been thanked: 0
thefisch
Post by thefisch » Mon Jul 29, 2019 11:53 am
Thanks. I was mainly trying to determine what that 'hose' is to understand how/if it relates to transmission fluid. Bit it appears to be a cable for an emissions sensor and just a 'victim' of the leak. Still need to inspect the car for the source.
dm635
Year and Model:
Has thanked: 0
Been thanked: 7 times
dm635
Post by dm635 » Mon Jul 29, 2019 5:34 pm
You are correct. That is not a hose. It's wiring from the O2 sensors. Looks like that pan has been sealed. You can now get a rubber seal that works much better than the old sealant you used to have to use.
96-964
91'745
86-635CSi 215K
Previous- 83 245T, 84 242, 85 242T, 92 960, 94 960, 95-964, 95-945
thefisch
Been thanked: 0
thefisch
Post by thefisch » Mon Jul 29, 2019 5:42 pm
Thanks for confirming that. And yes the pan was sealed due to a leak about 10 years ago. That's good to know they have a rubber seal in case that's where the leak is.
thefisch
Been thanked: 0
thefisch
Post by thefisch » Tue Jul 30, 2019 3:33 pm
Was able to inspect today and the leak is coming from the servo cover in the upper left of the first photo posted above. Fluid is seeping out and, thanks to the wind, running down lip of the pan towards the back of the pan and also getting on the cables adjacent to the pan lip. Going to check on replacing the o-rings. Good news is the leak was small.
