1995 Volvo 960 No Start Injector pulse issue PLEASE HELP!
brads960
Year and Model: 1995 960
Post by brads960 »
Hello everyone,
I have a 1995 Volvo 960. I bought it for next nothing and it wasn't running, now I have it running, but the kicker is... I can only start it on starter fluid. The car runs great when it is started and drives fine, but hot or cold the engine will not start on its own. I tested the fuel injector pulse on start up and for some reason it gives no pulse. I have changed the coolant temp sensor, the camshaft position sensor, the fuel pump and filter. I know it has spark because it runs well with no misfire, and the fact that it starts on starter fluid indicates fuel problem.
I believe there is something going on that is limiting the fuel on start up only, maybe electrical issue? I have checked all grounds, but I am not sure why the injectors wont pulse on start up.
Please give me some help on this issue! Thank you all for your time :)
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Try: Turn key to POS II, wait 15 seconds, crank.
Active
Past
brads960
Post by brads960 »
I tried that with no luck. I should have mentioned the codes it has...
Codes :
A-1: 213
A-2: 131, 223, 113
B-2: 122
pedro99
Year and Model: 1995 850 Turbo
Post by pedro99 »
Hey, i think i'm having the same issue and i can't find the solution anywhere, could you share what solved the issue for you?
danielb314
Year and Model: 1996
Post by danielb314 »
pedro99, long shot, but check if your car has an immo box (although most likely not in 1995), I just had a no start issue because of that..
