Maintenance Overdue Message
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
What is the year and model? Below is the Owner's Manual Look Up. For most the lights on an 03 S80 they want you to visit the dealer: "The light will stay on for 2 minutes after start until reset by the servicing retailer."
http://volvo.custhelp.com/app/homeV3
Katten
Year and Model: S80 3.2 2007
Has thanked: 1 time
Been thanked: 2 times
Post by Katten »
Depends on model year, let me know which year and I can translate the Swedish instructions I have :). It is done without anything external, just pushing buttons in the car.
MoVolvos
Post by MoVolvos »
Katten wrote: 11 Aug 2019, 13:40 Depends on model year, let me know which year and I can translate the Swedish instructions I have :). It is done without anything external, just pushing buttons in the car.
Hi Katten,
Mine is on. It's an 03 S80 T6 Elite. Please let me know if I can take care of this without the dealer. Thanks.
Katten
Has thanked: 1 time
Post by Katten »
Try this, it was hard to understand since proceedure seems to be different between 02 and 03 cars. Hope this works, if not let me know!
- Turn key to Position 1
- Press and hold trip reset button
- Turn key to Position 2 within 2 seconds
- Keep the trip reset button pressed untill yellow triangle lights up in the dash.
- Then release it, audible signal will indicate service reminder reset.
- You must release trip reset button within 4 seconds after yellow triangle lights up. In case trip meter was allready reset when you started it might take 10-14 seconds before the yellow triangle lights up.
Katten
Has thanked: 1 time
Post by Katten »
Maybe this helps too:
Step 1. Confirm that you have the trip computer in T-1 mode;
Step 2. Put the car key, and turn the ignition to position I ;
Step 3. Press and hold trip meter reset button until the trip meter reads “0.0”. Do not release trip meter reset button;
Step 4. With the trip meter reset button still pressed, turn the key to position “II”;
Step 5. When original trip mileage returns OR the orange warning light in the center of the dash flashes, release the trip meter reset button;
Step 6. Turn the car key to “off” position “0”.
MoVolvos
Post by MoVolvos »
Katten wrote: 12 Aug 2019, 04:56 Maybe this helps too:
Thanks for both I will take a looks later in the week.
