Dot 3 Brake Fluid
2001 - 2007 XC-70
eamonnpetty
Year and Model: 2009 Volvo S60 2.5t
Dot 3 Brake Fluid
Post by eamonnpetty »
I just went to the store and bought some dot 3 brake fluid to top off my cars level (2009 Volvo s60 2.5t). Looking at the cap for the brake fluid in my car it says, "Warning. Only use dot 4 brake fluid". But is it really all that serious or should I go back to the store and pick up some dot 4?
jimmy57
Been thanked: 265 times
Re: Dot 3 Brake Fluid
Post by jimmy57 »
Go get DOT 4. If your brake pads are worn and the level is above the low line on res then don't add any. The brake fluid level goes down as the pads wear as the caliper piston greater extension increases the volume of fluid held in each caliper. If you add when pads are worn then when pads get replaced and the pistons get pushed backed into bores the fluid returns to res and runs out onto inner fender.
The level will go to a little below half way when pads are worn to minimum level. If it gets low enough to be of concern the fluid level sensor will turn on a warning.
eamonnpetty
Thats the reason I bought the fluid. I had a low level warning pop up. Should I add a little or wait until I replace the pads?
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 37 times
Been thanked: 82 times
Post by MoVolvos »
eamonnpetty wrote: Tue Jul 30, 2019 9:00 am Thats the reason I bought the fluid. I had a low level warning pop up. Should I add a little or wait until I replace the pads?
Most generic fluids are DOT 3 & 4. See if yours is for both. If not get a turkey baster and remove and replace with DOT 4.
https://www.amazon.com/s?k=turkey+baste ... _ss_i_4_13
Slower but less messy - Can attach a tube
https://www.amazon.com/Medline-Sterile- ... 173&sr=8-7
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
MoVolvos
Post by MoVolvos »
I prefer to fill up and then remove some before working on the brakes.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
Has thanked: 378 times
Been thanked: 1185 times
You shouldn’t ever add brake fluid To a maintained car because:
You replace the brake fluid every two years per the manufacturer schedule.
In two years, unless you are a taxi, you wont use enough brake pad to cause the level to drop.
When you replace it every other year, fill to the max mark and out a black sharpie level marks o you can monitor it for fluid loss.
Fluid loss means park car.
Pull that DOT 3 out and replace with DOT4
Link To Volvo Glossary
