Need 98 v70 xc driver seat wiring diagram
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
So here i am with no 98 v70 xc
, thinking about calling the owner to bring it back. In the meantime, im going to assume i wont get it back and turn the driver seat into a powered rolly rolly house chair
Will convert it back if i do get it back. Im starting on the driver seat. I have most connections for it minus 1. I certainly dont want to wire in the airbag unless i wanna go flying into the back door or rolling *splat* into the wall
So i need wiring diagrams to guide me through all the wiring here. Basically i would like all functions, including heat and excluding airbag, to work (i have both button modules for the seat). I have all driver seat connections pictured. I also have the external black wiring (pictured) that will run to the wall.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- Has thanked: 316 times
- Been thanked: 531 times
That's a great idea, I've wanted to do this for a while. It would make a super comfortable chair!
Here are the diagrams for the seat heater as well as the power seats.
'98 Heated seats.pdf- (443.31 KiB) Downloaded 457 times
'98 power seats.pdf- (523.34 KiB) Downloaded 570 times
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
FWIW - The SIPS bag on a ‘98 seat is mechanical.
Be REALLY careful when you pull the side cover
with the switches. You’ll find an orange clip inside
that cover that will lock out the round mechanical
actuator under there. Not sure how to safely disable it...
- CIK7
Thank you so much! I have to wait to download and view them. ATT messed up my double data again and the first part ran out.bmdubya1198 wrote: 30 Jul 2019, 12:17 That's a great idea, I've wanted to do this for a while. It would make a super comfortable chair!
I forgot to include some info on my original post. Since the seat would not be bolted down when i lay back (and not much higher up than they normally are), i have to come up with a simple device to prevent the seat falling backwards, sooooooo with that in mind, I think im going to create a wheelie bar that i can lock and unlock at the rear center of the castor wheel contraption.
- CIK7
Which of the 3 cylinders manages the air bag?BEJinFbk wrote: 30 Jul 2019, 12:28 FWIW - The SIPS bag on a ‘98 seat is mechanical.
- BEJinFbk
Are you talking about the motors inside the seat frame?
No connection at all with the bags. They just move the seat.
- BEJinFbk
The little round unit I’m talking about is a charge encased
in a flying saucer shaped can on the outer SIDE of the seat.
IIRC, it’s an inch or two in diameter and maybe an inch thick.
The safety clip should be attached to the inside of the cover
panel and it slides betwen the actuater and the seat frame.
Again, it’s found under the side cover that the seat controls
are mounted in. It blows a small charge under impact that
travels up a small tube to the side bag. Hit it, you’ll know!
I've always been curious to try that at the junkyard...BEJinFbk wrote: 30 Jul 2019, 13:49 The little round unit I’m talking about is a charge encased
- CIK7
Ok in reference to the pictures i posted, youll see the one connection with 2 red and orange wires. Is that the air bag? I dont have the car anymore just the seats, but i do remmber disconnecting the orange clip. The car had sat dead for about 3 years.BEJinFbk wrote: 30 Jul 2019, 13:28 ....?
- 2591 Views
Last post by legalstuff
- 1627 Views
Last post by volvolugnut
- 1608 Views
Last post by CIK7
- 1066 Views
- 5002 Views
Last post by KaiHugo
