Should I try and do a head gasket repair myself??
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
jeffstuckinpa
Year and Model: 2005 xc90 2.5T AWD
Post by jeffstuckinpa »
Small oil/coolant leak into the spark plugs...
2005 2.5t awd
Is it worth me attempting??
Thanks
SuperHerman
Been thanked: 170 times
Re: Should I try and do a head gasket repair myself??
Post by SuperHerman »
There are plenty of write ups on the process. It is not easy, but not difficult. You need the cam lock tools. Basically you have to take off the upper cam cover, replace the o-rings and then reseal with anaerobic sealant if your problem is only the o-rings between the head and the upper timing cover.
I have one issue - the coolant. Generally it is just oil - I don't understand how coolant is getting in there.
That said, you may have a bad head gasket and leaking oil seals.
I would approach it as a complete head gasket job - have the head machined and pressure tested. Replace the valve stem seals, lap the valves and replace all the seals including the cam shafts.
RickHaleParker
Has thanked: 3 times
Been thanked: 608 times
Post by RickHaleParker »
Wipe out the oil & coolant then drive it, recheck after. It might just be spillage.
2004 S60R, B8444S TF80 AWD.
