Did you know? 🤔
fuel pump replaced and new doubt/question in XC90 2009
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
chimenes22
Year and Model: 2009
Has thanked: 0
Been thanked: 0
Brazil
chimenes22
Post by chimenes22 » Wed Jul 31, 2019 5:20 pm
Good morning everyone. Starting my experience with volvo with an XC90 3.2 2009. I bought the car not working, and from the beginning thought it would be the fuel pump. And it really was. We installed the new pump, and the car started perfectly. But I put only 20 liters of fuel to start the car. It worked for 30 minutes and I turned off the car. I started again, but it didn't start, so I put another 20 liters and it did normally. I saw that the tank is divided into two parts.
Do you need to fill one side first, that is, fill the tank for the rooster to pass to the other side? did I make a mistake or is that so? because looking at the tank picture it has two compartments ... does anyone know anything about this?
oragex
Year and Model: S60 2003
Has thanked: 84 times
Been thanked: 200 times
Canada
oragex
Re: fuel pump replaced and new doubt/question in XC90 2009
Post by oragex » Thu Aug 01, 2019 4:45 pm
There have been indeed a few problems with fuel not passing from one side of the tank to the other side. Not sure if you have two pumps or just a long hose going to the other side, perhaps try asking on S60 forums, with some luck you will find someone who already had this issue (and while there also try other forums like http://www.volvoxc.com/forums/forumdisp ... 70-(V70XC) and https://forums.swedespeed.com/forumdisp ... 2001-2010) because this issue is not very common
Has thanked: 0
Been thanked: 89 times
United States of America
Post by cn90 » Sat Aug 03, 2019 3:45 pm
In the BMW, this is known as "siphon pump" (Venturi effect) failure.
Idk about Volvo transfer pump, still learning...
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Has thanked: 0
Been thanked: 51 times
ggleavitt
Post by ggleavitt » Sun Aug 04, 2019 10:29 am
Don't get stuck on the specific symptom this user had, see- viewtopic.php?f=10&t=83957 for a more detailed description of the fuel delivery system.
This is a pump replacement tutorial, the tank and pump layout with the XC90 is the same over the range- https://volvoforums.com/forum/volvo-xc9 ... ial-70880/
No idea all that you did, for 100% sure it's important that the secondary hose be routed properly on other side of the tank (see mention of tying a string to make things easier).
Good luck
edit 080419- tank and pump layouts are the same, individual pump PNs will be different depending on chassis (last 6 of VIN) and tank size.
2005 2.5T AWD-196k
2008 V8 AWD Sport-126k
