2006 C70
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Rubem
Year and Model: 2006 C70
Has thanked: 2 times
2006 C70
Post by Rubem »
Only 75 k miles...
Full of issues!
Already changed rear chocks, battery and fuel sensor.
Heats up and cools while going or at a red light stop.
Water lowers but no leak visible .
Oil Ok.
No spots on the ground.
Check engine light on forever.
Had a code at MIDAS for exhaustion system...
Smells somewhat as exhaustion is perforated.
Starts but shakes (likely engine intermittent), plus dies suddenly and/or won't start after turn off... takes several tries to start again.
Auto mechanics are feasting on me!
One said it should be the catalytic converter...
Help!!!
June
Year and Model: 2004 S80 T6
Has thanked: 350 times
Been thanked: 177 times
Re: 2006 C70
Post by June »
Do you mean the temperature gauge is going beyond half way? Coolant disappearing is not normal. If no external leak visible, a combustion gas test needs to be performed to rule out a bad head gasket. Catalytic converter will not cause the coolant level to lower or engine to overheat. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 37 times
Been thanked: 82 times
Re: 2006 C70
Post by MoVolvos »
June wrote: Fri Aug 02, 2019 4:16 pm Coolant disappearing is not normal. (+1) If no external leak visible, a combustion gas test needs to be performed to rule out a bad head gasket.
The coolant is probably smothering the engine combustion. The liquid is around $8 to $10 dollars. You can borrow/loan the bulb kit from O'Reilly or Advance Auto. Forgot to return mine so it's mine as you pay for it in full and get a complete refund with you return it.
Testing for Bad Head Gasket or Cracked Head or Block
This guy is pretty good
CHECKING A BLOWN HEAD GASKET WITH NO SPECIALIZED TOOLS (EASY 4 THE DIYer) DO IT YOURSELF SAVE$$$
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
